  • Dayton Audio PA130-8 5" Full Range PA Driver
Dayton Audio
Part #295-010
Dayton Audio
Part #295-010
Model: PA130-8
A great low-cost driver designed for use in small stage monitors, either as a replacement driver or for new construction. The broad frequency coverage and flat midrange ensure that vocals and instruments will sound just like they should.
  • Great low-cost driver designed for use in small stage monitors
  • Broad frequency coverage and flat midrange ensure that vocals and instruments sound perfect
  • Rugged construction
Your Price: $19.98
MSRP: $29.99
Save $10.01 (33%)
Quantity:Qty: 1-3 $19.98/ea
Quantity:Qty: 4+$18.48/ea
26In Stock
A great low-cost driver designed for use in small stage monitors, either as a replacement driver or for new construction. The broad frequency coverage and flat midrange ensure that vocals and instruments will sound just like they should. Rugged construction includes a steel frame, paper cone, treated cloth surround, vented pole piece and a large 20 oz. magnet.
Also available in a 16 ohm version: Dayton Audio PA130-16
ModelPA130-8
Part Number295-010
UPC844632000195
Weight2.65
Nominal Diameter5"
Power Handling (RMS)50 Watts
Power Handling (MAX)100 Watts
Frequency Response90 to 15,000Hz
Sensitivity88.2dB 2.83V/1m
Voice Coil Diameter1"
Resonant Frequency (Fs)83.4Hz
DC Resistance (Re)7.1Ω
Voice Coil Inductance (Le)0.71mH
Mechanical Q (Qms)3.21
Electromagnetic Q (Qes)0.6
Total Q (Qts)0.51
Compliance Equivalent Volume (Vas)0.14ft³
Mechanical Compliance of Suspension (Cms)0.54mm/N
BL Product (BL)6.44T·m
Diaphragm Mass Inc. Airload (Mms)6.8g
Surface Area of Cone (Sd)73.9cm²
Cone MaterialPaper
Surround MaterialCloth
Voice Coil FormerAluminum
Overall Outside Diameter5.2"
Baffle Cutout Diameter4.41"
Depth2.66"
Sealed Volume0.07ft³
Sealed F3140Hz
Vented Volume0.25ft³
Vented F370Hz
MONSTER DEAL
OF THE WEEK
$19.98 EACH
SAVE $10
