  • Dayton Audio DSS2-BK Black Speaker Spike Set 4 Pcs.
Dayton Audio
Part #240-664
Dayton Audio
Part #240-664
Model: DSS2-BK
Rigidly coupling a loudspeaker enclosure to a floor by means of a "spiking" system dramatically improves clarity, stereo imaging, and bass response.
Your Price: $9.98
MSRP: $12.99
Save $3.01 (23%)
Quantity:Qty: 1-9 $9.98/ea
Quantity:Qty: 10+$8.98/ea
Rigidly coupling a loudspeaker enclosure to a floor by means of a "spiking" system dramatically improves clarity, stereo imaging, and bass response. This is especially apparent with subwoofer systems. These attractive spikes are precision machined from solid brass and then plated with a durable finish. Barbed insert nuts and 6 mm threaded studs are included for mounting in cabinets with walls up to 1" thick. Set includes four cone spikes, four floor discs, four barbed insert nuts, and four threaded studs. Insert nut requires a 5/16" hole to be drilled in cabinet prior to installation. • Dimensions: 9/16" diameter, 5/8" high (including disc).
ModelDSS2-BK
Part Number240-664
UPC844632083358
Weight0.2
Color / FinishBlack
Construction MaterialBrass
