  • Dayton Audio DSS2-SN Satin Nickel Speaker Spike Set 4 Pcs.
Dayton Audio
Part #240-668
Dayton Audio
Part #240-668
Model: DSS2-SN
Rigidly coupling a loudspeaker enclosure to a floor by means of a "spiking" system dramatically improves clarity, stereo imaging, and bass response.
Your Price: $9.98
MSRP: $12.99
Save $3.01 (23%)
Quantity:Qty: 1-9 $9.98/ea
Quantity:Qty: 10+$8.98/ea
Rigidly coupling a loudspeaker enclosure to a floor by means of a "spiking" system dramatically improves clarity, stereo imaging, and bass response. This is especially apparent with subwoofer systems. These attractive spikes are precision machined from solid brass and then plated with a durable finish. Barbed insert nuts and 6 mm threaded studs are included for mounting in cabinets with walls up to 1" thick. Set includes four cone spikes, four floor discs, four barbed insert nuts, and four threaded studs. Cone is 5/8", insert requires a 5/16" hole to be drilled prior to installation. • Dimensions: 9/16" diameter, 5/8" high (including disc).
ModelDSS2-SN
Part Number240-668
UPC844632083372
Weight0.2
Color / FinishSatin Nickel
Construction MaterialBrass
MONSTER DEAL
OF THE WEEK
$19.98 EACH
SAVE $10
