  • Dayton Audio DS270-PR 10" Designer Series Passive Radiator
Dayton Audio
Part #295-494
Dayton Audio
Part #295-494
Model: DS270-PR
The Dayton Audio Passive Radiators are excellent general-purpose passives suitable for replacement or for new construction.
Your Price: $36.98
MSRP: $44.99
Save $8.01 (18%)
Quantity:Qty: 1-3 $36.98/ea
Quantity:Qty: 4+$33.28/ea
Order in the next 4 hr 36 min to ship today. Details
Only 7 In Stock
More due any day
The Dayton Audio Passive Radiators are excellent general-purpose passives suitable for replacement or for new construction. A built-in mass disc offers a good starting point for most designs, and a convenient M5 threaded hole (screw included) allows different types of weights to be added if desired. Cosmetically and mechanically, the passives match the Shielded DVC line of subwoofers, with a poly coated paper cone and medium-roll rubber surround for clean excursion and long life. The possibilities with these passives are endless, from floor standing two-ways to small active/passive subwoofer systems.
Specifications: • Fs: 21.9 Hz • Vas: 3.73 cu. ft. • Qms: 3.98 • Cms: 0.60 mm/N • Rms: 3.1 kg/ • Mms: 88.4 g • Sd: 353 sq. cm. • Xmax: 11 mm • Dimensions: Overall diameter: 10.63", Cutout diameter: 8.94", Depth: 2.81".
Note: Adding mass to the passive radiator will decrease Fs and increase Qms.
Tip: As a general rule the passive radiator(s) should be able to move double the volume of air as the active woofer(s)/subwoofer(s) in the system. For example: A passive radiator system for a 10" woofer/subwoofer that has 10mm of X-max would require 2-10" passive radiators with 10mm of X-max. For single passive radiator systems, it is common to use a passive that is larger than the active woofer(s)/subwoofer(s).
ModelDS270-PR
Part Number295-494
UPC844632000409
Weight1.5
Nominal Diameter10"
Resonant Frequency (Fs)21.9Hz
Mechanical Q (Qms)3.98
Compliance Equivalent Volume (Vas)3.73ft³
Mechanical Compliance of Suspension (Cms)0.6mm/N
Diaphragm Mass Inc. Airload (Mms)88.4g
Maximum Linear Excursion (Xmax)11mm
Surface Area of Cone (Sd)353cm²
Cone MaterialPaper
Overall Outside Diameter10.63"
Baffle Cutout Diameter8.94"
Depth2.87"
# Mounting Holes5
