  • Dayton Audio DS270-8 10" Designer Series Woofer Speaker
Dayton Audio
Part #295-432
Dayton Audio
Part #295-432
Model: DS270-8
The Dayton Audio Designer Series DS270-8 10" can operate at its full rated power down to 27 Hz without exceeding Xmax!
  • Cosmetic frame with low profile lip, designed for front mounting—no countersinking required!
  • Coated paper cone, half roll rubber surround for durability and accurate reproduction
  • Optimized to yield a low 3 dB down point and high potential output in a reasonably sized cabinet
  • Smooth frequency response and linear roll-off simplify filter design, guaranteeing good results with off-the-shelf crossovers
  • Vented pole piece for minimized power compression and maximized reliability
  • Generous Xmax capability encourages use of moderate bass boost to tailor the response
  • Retains the same "family look" as the popular Dayton Audio DVC Series subwoofers and passive radiators
Your Price: $69.98
MSRP: $102.99
Save $33.01 (32%)
Order in the next 8 hr 5 min to ship today. Details
The Designer Series by Dayton Audio was developed specifically with the speaker designer in mind. It is an affordable, attractive line of drivers that puts performance first. Careful engineering ensures that each speaker in the series is capable of handling full rated power at the lowest possible frequencies—without exceeding Xmax.
These speakers combine useful performance parameters with elegant style. Carefully optimized to provide superb audio reproduction when incorporated into a wide variety of enclosures and alignments, the Designer Series transducers put a beautiful face on audiophile excellence.
ModelDS270-8
Part Number295-432
UPC844632095429
Weight10.3
Nominal Diameter10"
Bolt Circle Diameter10.24
Power Handling (RMS)100 Watts
Power Handling (MAX)200 Watts
Frequency Response30 to 3,000Hz
Sensitivity90.7dB 2.83V/1m
Voice Coil Diameter1.52"
Resonant Frequency (Fs)31.6Hz
DC Resistance (Re)5.4Ω
Voice Coil Inductance (Le)1.25mH
Mechanical Q (Qms)2.4
Electromagnetic Q (Qes)0.54
Total Q (Qts)0.44
Compliance Equivalent Volume (Vas)3.09ft³
Mechanical Compliance of Suspension (Cms)0.48mm/N
BL Product (BL)10.1T·m
Diaphragm Mass Inc. Airload (Mms)56.4g
Maximum Linear Excursion (Xmax)5.5mm
Surface Area of Cone (Sd)353cm²
Cone MaterialCoated Paper
Voice Coil FormerAluminum
Overall Outside Diameter10.63"
Baffle Cutout Diameter8.94"
Depth4.41"
# Mounting Holes5
Sealed Volume1.3ft³
Sealed F357Hz
Vented Volume2ft³
Vented F338Hz
MONSTER DEAL
OF THE WEEK
$24.98 EACH
SAVE $5
Lepai LP-2020BT Bluetooth Hi-Fi Audio Mini Class D Stereo Amplifier FM Media with Power Supply
