  • Dayton Audio BPA-38SN HD Binding Post Banana Jack Pair Satin Nickel
Dayton Audio
Part #091-1247
Dayton Audio
Part #091-1247
Model: BPA-38SN
These heavy-duty binding posts were designed with the audiophile in mind. The high-quality plating process eliminates the possibility of corrosion to maintain the highest possible signal transfer and resist harsh environmental conditions.
  • Satin nickel
  • Audiophile quality
  • Ideal for high power applications
  • Non-oxidizing
Your Price: $9.98
MSRP: $11.99
Save $2.01 (17%)
Quantity:Qty: 1-9 $9.98/ea
Quantity:Qty: 10+$8.98/ea
These heavy-duty binding posts were designed with the audiophile in mind. The high-quality plating process eliminates the possibility of corrosion to maintain the highest possible signal transfer and resist harsh environmental conditions. The binding posts can be used with banana plugs or will accept wire up to 8 gauge. The large diameter knurled head allows for positive finger tight connections. Extra long rear bolt (1-1/2") for mounting in speaker cabinets with walls up to 1" thick (3/8" minimum thickness). To install, simply drill a 1/4" hole and gently tap the binding post in place. The knurled shaft will keep the post from turning and creates an air-tight fit. Overall length is 2-1/4". Sold in color-coded pairs with solder tabs.
ModelBPA-38SN
Part Number091-1247
UPC844632019203
Weight0.15
Contact PlatingSatin Nickel
Style / TypeSingle
