  • Audio Technica ATW-T1406 System 20 PRO Boundary Microphone
NEW Audio Technica ATW-T1406 System 20 PRO Boundary Microphone
Audio-Technica
Part #240-5757
Audio-Technica
Part #240-5757
Model: ATW-T1406
Take the freedom of a wireless system anywhere with Audio-Technica's System 20 PRO series! Endlessly customizable, the System 20 PRO line of microphones, bodypacks, and more can easily be personalized to fit your needs. With the ATW-T1406, you have a boundary microphone transmitter to begin your system or expand your pre-existing setup. Never stress about having a quality microphone for the big meeting again!
  • Fully integrated with the System 20 PRO line
  • Cardioid polar pattern will reduce background noise and keep the focus on the user
  • Selectable mute operation (toggle, touch-to-talk, or touch-to-mute)
  • Standard and Conference modes for the LEDs
  • OLED display lets you adjust your settings quickly and discretely
  • Up to 12 hours of battery life for a full day's work
  • Charged via USB Type-C, and usable while charging
NEW $399.00
Audio-Technica's System 20 Pro Series
The wireless system you can use anywhere!
The Audio Technica ATW-T1406 boundary microphone transmitter from the System 20 PRO line has you covered when you need to capture the sounds of a conference table. With the choice of toggle, touch-to-talk, and touch-to-mute, you're covered in all scenarios. The OLED display on the bottom makes setting up simple, and the LED on top can also be set in standard mode or conference mode. The internal lithium-ion batteries last up to 12 hours for a full day's work, or be used while charging via USB Type-C.
Please note that this transmitter will require an Audio-Technica ATW-R1440 receiver. The ATW-T1406 boundary microphone transmitter is for adding to a pre-existing System 20 PRO wireless system or starting a new system with a separate ATW-R1440 receiver.
System 20 PRO Features
  • Digital 24-bit/48 kHz wireless operation for ultimate sound quality and dependable performance
  • Plug-and-play operation in the 2.4 GHz range – completely free from TV interference
  • User can switch between Standard mode (10 channels) and HD mode (20 channels) to minimize latency or maximize channel count, respectively
  • Receiver units can be docked in the chassis or mounted remotely (up to 328 feet away) via Ethernet cable for added versatility
  • Up to five chassis can be linked and used simultaneously
  • Each receiver channel can be paired with up to four transmitters, allowing users to instantly switch between different transmitter configurations
  • Chassis’ System ID Display shows RF signal level, system ID, transmitter battery level, and system link status
  • Each half-rack receiver chassis comes with a short and a long rack ear, and two long ears can be combined as a joining plate to secure two chassis in a full rack space
  • Compatible with Audio-Technica’s Wireless Manager Software software for centralized management of system settings and operations
  • Auto-lock function prevents unintended operations like turning off the power or displaying the channel select screen
  • AES128 encryption for security
  • Compatible with Syslog protocol
  • Ability to configure, monitor, and save device settings as projects in Wireless Manager
  • Transmitters and receivers include OLED screens for optimal readout of key settings and alerts
  • Water- and sweat-resistant cW-style connector on ATW-T1401 body-pack transmitter provides secure connection to lavalier mics, headworn mics, and cables with cW-style locking 4-pin connector
  • Charging terminals on body-pack and handheld transmitters work with ATW-CHG3/ATW-CHG3a and ATW-CHG3N/ATW-CHG3Na charging docks to recharge NiMH batteries
  • Supports mixed output for situations with limited input channels
General Specifications
  • Operating Frequencies: 2,402 to 2,480 MHz
  • Dynamic Range: 120 dB (A-weighted), typical
  • Total Harmonic Distortion: < 0.05%, typical
  • Maximum Simultaneous Use (recommended):
    -Standard: 10 channels
    -HD mode: 20 channels
    It depends on the region and environment.
  • System Frequency Response: 20 to 20K Hz
    Varies depending on the microphone to be installed.
  • Delay:
    -Standard: 2.8ms
    -HD mode: 6.7ms
  • Audio Sampling Rate:
    -Standard: 24-bit/48 kHz
    -HD mode: 24-bit/48 kHz
  • Encryption Method: AES128
ATW-T1406 Boundary Mic Specifications
  • Modulation Mode: GFSK
  • RF Output Power: 10mW EIRP
  • RF Sensitivity: -90 dBm, typical
  • Antenna: True diversity
  • Maximum Input Sound Pressure Level: 139 dB SPL
  • Microphone Type: Condenser
  • Microphone Polar Pattern: Cardioid
  • Built-in Battery: 3.7V lithium-ion battery (5.5Wh, 1460mAh)
  • Battery Life: Approx. 12 hours
    This varies depending on usage conditions.
  • Charging Time: Approx. 3 hours and 10 minutes
  • USB Charging Port: USB Type-C (USB 2.0)
  • Operating Temperature Range: 5ºC to +40ºC (41°F to 104°F)
  • Dimensions: 90.5 mm (3.6") × 129.4 mm (5.1") × 31.9 mm (1.3") (W × D × H)
  • Weight (with battery): 510 g (18 oz)
  • Included Accessories: USB power supply adapter, USB power supply adapter blade, USB cable (1.5 m [4.9'])
Ready-to-Go Systems from System 20 PRO
Keep things simple and buy one of Audio-Technica's pre-made systems! The transmitters included in each system are paired and ready to use out of the box, and offer all-day operation on a full charge.
ATW-1421 Dual Body-Pack System
ATW1422 Dual Handheld Microphone System
ATW-1423 Dual Handheld and Body-Pack System
System 20 Pro Components
Build your system from the ground up to be confident you have exactly what you need to meet your demands!
ATW-R1440 4 Channel Receiver
ATW-T1402 Handheld Wireless Mic
ATW-T1401 Body-Pack Transmitter
ATW-T1406 Boundary Microphone
ATW-T1407 Desk Stand Transmitter
BrandAudio-Technica
ModelATW-T1406
Part Number240-5757
UPC4961310161545
Weight1.87
MONSTER DEAL
OF THE WEEK
$19.98 EACH
SAVE $10
