  • Audio Technica ATW-R1440 System 20 PRO 4 Channel Receiver
NEW Audio Technica ATW-R1440 System 20 PRO 4 Channel Receiver
Audio-Technica
Part #240-5754
Audio-Technica
Part #240-5754
Model: ATW-R1440
Take the freedom of a wireless system anywhere with Audio-Technica's System 20 PRO series! Endlessly customizable, the System 20 PRO line of microphones, bodypacks, and more can easily be personalized to fit your needs. With the ATW-R1440, you have a four channel receiver to to begin your system or expand your pre-existing setup. Add a wireless mic, body-pack, or any other System 20 PRO transmitter to leave concerns of managing and tripping on wires behind for good!
  • The beating heart of the System 20 PRO line
  • Pairable with up to four transmitters at once
  • Receiver and chassis can be placed separately and connected via ethernet to ensure a clear signal from your transmitters
  • Monitor transmitter status, audio level, remaining battery time, and other information in A-T Wireless Manager
  • Up to five chassis can be linked and used simultaneously
  • All hardware is included to rack mount the chassis with the rest of your equipment
  • Auto-lock function prevents unintended operations
NEW $599.00
Order in the next 15 hr 46 min to ship today. Details
Audio-Technica's System 20 Pro Series
The wireless system you can use anywhere!
The Audio Technica ATW-R1440 4-channel receiver is composed of one ATW-RC14 Receiver and one ATW-RU14 Chassis. The receiver can be undocked and mounted separately in the included cover and connected via ethernet up to 328' away from the chassis, giving the user significantly more optionality in setup. Each receiver can pair with up to four transmitters, and up to five chassis can be linked and used simultaneously. With the included hardware, the chassis can be mounted solo in a rack or two can be mounted side-by-side. And with the auto-lock function, you'll be safe from accidently changing your settings.
Please note this receiver does not come with any transmitters. The ATW-T1440 4-channel receiver is for adding to a pre-existing System 20 PRO wireless system or starting a new system with a separate transmitter such as a ATW-T1401 body-pack or ATW-T1402 handheld microphone.
System 20 PRO Features
  • Digital 24-bit/48 kHz wireless operation for ultimate sound quality and dependable performance
  • Plug-and-play operation in the 2.4 GHz range – completely free from TV interference
  • User can switch between Standard mode (10 channels) and HD mode (20 channels) to minimize latency or maximize channel count, respectively
  • Receiver units can be docked in the chassis or mounted remotely (up to 328 feet away) via Ethernet cable for added versatility
  • Each receiver channel can be paired with up to four transmitters, allowing users to instantly switch between different transmitter configurations
  • Chassis’ System ID Display shows RF signal level, system ID, transmitter battery level, and system link status
  • Each half-rack receiver chassis comes with a short and a long rack ear, and two long ears can be combined as a joining plate to secure two chassis in a full rack space
  • Compatible with Audio-Technica’s Wireless Manager Software software for centralized management of system settings and operations
  • Auto-lock function prevents unintended operations like turning off the power or displaying the channel select screen
  • AES128 encryption for security
  • Compatible with Syslog protocol
  • Ability to configure, monitor, and save device settings as projects in Wireless Manager
  • Transmitters and receivers include OLED screens for optimal readout of key settings and alerts
  • Water- and sweat-resistant cW-style connector on ATW-T1401 body-pack transmitter provides secure connection to lavalier mics, headworn mics, and cables with cW-style locking 4-pin connector
  • Charging terminals on body-pack and handheld transmitters work with ATW-CHG3/ATW-CHG3a and ATW-CHG3N/ATW-CHG3Na charging docks to recharge NiMH batteries
  • Supports mixed output for situations with limited input channels
Mounting Options
Undock the Receiver from the Chassis and mount remotely for a significantly greater versatility in your setup options!
Remove the ATW-RC14 Receiver from the ATW-RU14 Chassis
Secure the ATW-RC14 Receiver in the included unit holder cover.
The ATW-RC14 Receiver can be mounted separately from the ATW-RU14 Chassis up to 328 ft. away via ethernet cable.
General Specifications
  • Operating Frequencies: 2,402 to 2,480 MHz
  • Dynamic Range: 120 dB (A-weighted), typical
  • Total Harmonic Distortion: < 0.05%, typical
  • Maximum Simultaneous Use (recommended):
    -Standard: 10 channels
    -HD mode: 20 channels
    It depends on the region and environment.
  • System Frequency Response: 20 to 20K Hz
    Varies depending on the microphone to be installed.
  • Delay:
    -Standard: 2.8ms
    -HD mode: 6.7ms
  • Audio Sampling Rate:
    -Standard: 24-bit/48 kHz
    -HD mode: 24-bit/48 kHz
  • Encryption Method: AES128
ATW-RC14 Receiver Specs
  • External Receiver Unit Port: RJ45
  • NETWORK Port: RJ45: Fast Ethernet
  • LINK IN/OUT Port: RJ12
  • Output Level:
    -LINE max: +22 dBu (+20 dBV)
    -LINE Unity: -20 Bu (-22 dBV)
    -MIC max: -12 dBu (-10 dBV)
    -MIC Unity: -50 dBu (-52 dBV)
  • Power Consumption: 3.7W
  • Power Supply: 12 V DC, 0.5 A (AC adapter)
  • Operating Temperature Range: 0ºC to +40ºC (32°F to 104°F)
  • Dimensions: 209.8 mm (8.3") × 165.6 mm (6.5") × 42.5 mm (1.7") (W × D × H)
  • Weight: 740 g (26 oz)
  • Included Accessories: AC adapter, AC adapter blade, short rack-mount adapter, long rackmount adapter, fixing screw × 5, link cable (30 cm [12"]), leg × 4
ATW-RU14 Chassis Specs
  • Modulation Mode: GFSK
  • RF Output Power: 10mW EIRP
  • RF Sensitivity: -90 dBm, typical
  • Antenna: 1/2 wave dipole antenna, true diversity
  • External Connection Port: RJ45
  • Power Supply: 12 V DC (RC14)
  • Dimensions: 86.0 mm (3.4") × 70.2 mm (2.8") × 18.7 mm (0.74") (W × D × H)
  • Weight: 77 g (2.7 oz)
  • Included Accessories: Unit holder, holder cover, wood screws x 2, antenna x 4
Ready-to-Go Systems from System 20 PRO
Keep things simple and buy one of Audio-Technica's pre-made systems! The transmitters included in each system are paired and ready to use out of the box, and offer all-day operation on a full charge.
ATW-1421 Dual Body-Pack System
ATW1422 Dual Handheld Microphone System
ATW-1423 Dual Handheld and Body-Pack System
System 20 Pro Components
Build your system from the ground up to be confident you have exactly what you need to meet your demands!
ATW-R1440 4 Channel Receiver
ATW-T1402 Handheld Wireless Mic
ATW-T1401 Body-Pack Transmitter
ATW-T1406 Boundary Microphone
ATW-T1407 Desk Stand Transmitter
BrandAudio-Technica
ModelATW-R1440
Part Number240-5754
UPC4961310161484
Weight4.04
MONSTER DEAL
OF THE WEEK
$19.98 EACH
SAVE $10
