  • Audio Technica ATW-T1402 System 20 PRO Handheld Wireless Microphone
NEW Audio Technica ATW-T1402 System 20 PRO Handheld Wireless Microphone
Audio-Technica
Part #240-5756
Audio-Technica
Part #240-5756
Model: ATW-T1402
Take the freedom of a wireless system anywhere with Audio-Technica's System 20 PRO series! Endlessly customizable, the System 20 PRO line of microphones, bodypacks, and more can easily be personalized to fit your needs. With the ATW-T1402, you have a handheld wireless microphone transmitter to begin your system or expand your pre-existing setup. Whether you're a singer, preacher, presenter, or just giving a speech at a wedding, free yourself up from tripping on cables with the liberty of a wireless handheld mic!
  • Fully integrated with the System 20 PRO line
  • Built for vocalists and performers who want to wander the stage without tangling up their cable
  • Two built-in antennas to help keep you connected
  • OLED display lets you adjust your settings even in a dark venue
  • Compatible with alkaline, lithium, or NiMH batteries
  • Lightweight yet hardy to be comfortable and survive on stage
  • Slide-to-mute switch for easy enabling/disabling
NEW $269.00
Audio-Technica's System 20 Pro Series
The wireless system you can use anywhere!
The Audio Technica ATW-T1402 handheld microphone transmitter from the System 20 PRO line offers performers the freedom to roam. Whether you're a singer, preacher, presenter, or just giving a speech at a wedding, free yourself up from tripping on cables with the liberty of a wireless handheld mic.
Each transmitter has two built-in antennas, a slide-to-mute switch, OLED display, and are compatible with NiMH batteries for all day use.
Please note that this microphone transmitter will require an Audio-Technica ATW-R1440 receiver. The ATW-T1402 handheld microphone transmitter is for adding to a pre-existing System 20 PRO wireless system or starting a new system with a separate ATW-R1440 receiver.
System 20 PRO Features
  • Digital 24-bit/48 kHz wireless operation for ultimate sound quality and dependable performance
  • Plug-and-play operation in the 2.4 GHz range – completely free from TV interference
  • User can switch between Standard mode (10 channels) and HD mode (20 channels) to minimize latency or maximize channel count, respectively
  • Receiver units can be docked in the chassis or mounted remotely (up to 328 feet away) via Ethernet cable for added versatility
  • Up to five chassis can be linked and used simultaneously
  • Each receiver channel can be paired with up to four transmitters, allowing users to instantly switch between different transmitter configurations
  • Chassis’ System ID Display shows RF signal level, system ID, transmitter battery level, and system link status
  • Each half-rack receiver chassis comes with a short and a long rack ear, and two long ears can be combined as a joining plate to secure two chassis in a full rack space
  • Compatible with Audio-Technica’s Wireless Manager Software software for centralized management of system settings and operations
  • Auto-lock function prevents unintended operations like turning off the power or displaying the channel select screen
  • AES128 encryption for security
  • Compatible with Syslog protocol
  • Ability to configure, monitor, and save device settings as projects in Wireless Manager
  • Transmitters and receivers include OLED screens for optimal readout of key settings and alerts
  • Water- and sweat-resistant cW-style connector on ATW-T1401 body-pack transmitter provides secure connection to lavalier mics, headworn mics, and cables with cW-style locking 4-pin connector
  • Charging terminals on body-pack and handheld transmitters work with ATW-CHG3/ATW-CHG3a and ATW-CHG3N/ATW-CHG3Na charging docks to recharge NiMH batteries
  • Supports mixed output for situations with limited input channels
General Specifications
  • Operating Frequencies: 2,402 to 2,480 MHz
  • Dynamic Range: 120 dB (A-weighted), typical
  • Total Harmonic Distortion: < 0.05%, typical
  • Maximum Simultaneous Use (recommended):
    -Standard: 10 channels
    -HD mode: 20 channels
    It depends on the region and environment.
  • System Frequency Response: 20 to 20K Hz
    Varies depending on the microphone to be installed.
  • Delay:
    -Standard: 2.8ms
    -HD mode: 6.7ms
  • Audio Sampling Rate:
    -Standard: 24-bit/48 kHz
    -HD mode: 24-bit/48 kHz
  • Encryption Method: AES128
ATW-T1402 Handheld Mic Specifications
  • Modulation Mode: GFSK
  • RF Output Power: 10mW EIRP
  • RF Sensitivity -90 dBm, typical
  • Antenna: True diversity
  • Battery: 3 V DC (two 1.5 V AA)
  • Battery Life:
    -Approx. 18 hours (alkaline)
    -Approx. 16 hours 30 minutes (Ni-MH)
    -Approx. 35 hours (lithium)
    This varies depending on usage conditions.
  • Microphone Type: Dynamic
  • Microphone Polar Pattern: Hypercardioid
  • Operating Temperature Range: 5ºC to +40ºC (41°F to 104°F)
  • Dimensions: 265.0 mm (10") × 53.7 mm (2.1")
  • Weight: 300 g (11 oz), without batteries
  • Included Accessories: Mic holder AT8456a, converting thread adapter (3/8" - 5/8")
Ready-to-Go Systems from System 20 PRO
Keep things simple and buy one of Audio-Technica's pre-made systems! The transmitters included in each system are paired and ready to use out of the box, and offer all-day operation on a full charge.
ATW-1421 Dual Body-Pack System
ATW1422 Dual Handheld Microphone System
ATW-1423 Dual Handheld and Body-Pack System
System 20 Pro Components
Build your system from the ground up to be confident you have exactly what you need to meet your demands!
ATW-R1440 4 Channel Receiver
ATW-T1402 Handheld Wireless Mic
ATW-T1401 Body-Pack Transmitter
ATW-T1406 Boundary Microphone
ATW-T1407 Desk Stand Transmitter
BrandAudio-Technica
ModelATW-T1402
Part Number240-5756
UPC4961310161521
Weight1.2
MONSTER DEAL
OF THE WEEK
$19.98 EACH
SAVE $10
