  • ALPS 20KAX2 20K Ohm Audio Taper Stereo Potentiometer 6mm Shaft
Part #023-200
Part #023-200
Model: 20KAx2
The Alps 20KAX2 is a 20K ohm stereo potentiometer of the highest quality. The 6 mm straight shaft is 25 mm long with M8 thru-hole mounting, hardware included. For over 6 decades, Alps has been made in Japan, and has also been the only choice for serious musicians, audiophiles, and technicians.
Your Price: $15.39
MSRP: $19.99
Save $4.60 (23%)
Quantity:Qty: 1-4 $15.39/ea
Quantity:Qty: 5+$13.85/ea
19In Stock
The Alps 20KAX2 is a 20K ohm stereo potentiometer of the highest quality. The 6 mm straight shaft is 25 mm long, with M8 thru-hole mounting, hardware included. The body of the potentiometer is 1.073" W  x 0.97" H x 0.93" D (27 x 24.5 x 24 mm) without terminals. 1/2 watt power rating, 30 VAC max. For over 6 decades, Alps has been made in Japan, and has also been the only choice for serious musicians, audiophiles, and technicians.
Maybe you're repairing, restoring, or hot rodding an existing guitar, amplifier, or other electronic equipment. Perhaps you're devising your own unique musical or audio gear from scratch, working on classic vintage receivers, radios, or TV sets. Any way you slice it, Parts Express has the quality components you need to finish the job right, at prices you can afford.
Model20KAx2
Part Number023-200
UPC848864029719
Electrical CharacteristicsLogarithmic / Audio Taper
Value20K
