  • ALPS 10KAX2 10K Ohm Audio Taper Stereo Potentiometer 6mm Shaft
Part #023-204
Part #023-204
Model: 10KAx2
The Alps 10KAX2 is a 10K ohm stereo potentiometer of the highest quality. The 6 mm straight shaft is 25 mm long with M8 thru-hole mounting, hardware included. For over 6 decades, Alps has been made in Japan, and has also been the only choice for serious musicians, audiophiles, and technicians.
Your Price: $15.39
MSRP: $19.99
Save $4.60 (23%)
Quantity:Qty: 1-4 $15.39/ea
Quantity:Qty: 5+$13.84/ea
114In Stock
The Alps 10KAX2 is a 10K ohm stereo potentiometer of the highest quality. The 6 mm straight shaft is 25 mm long, with M8 thru-hole mounting, hardware included. The body of the potentiometer is 1.073" W  x 0.97" H x 0.93" D (27 x 24.5 x 24 mm) without terminals. 1/2 watt power rating, 30 VAC max. For over 6 decades, Alps has been made in Japan, and has also been the only choice for serious musicians, audiophiles, and technicians.
Maybe you're repairing, restoring, or hot rodding an existing guitar, amplifier, or other electronic equipment. Perhaps you're devising your own unique musical or audio gear from scratch, working on classic vintage receivers, radios, or TV sets. Any way you slice it, Parts Express has the quality components you need to finish the job right, at prices you can afford.
Model10KAx2
Part Number023-204
UPC848864029733
Electrical CharacteristicsLogarithmic / Audio Taper
Value10K
MONSTER DEAL
OF THE WEEK
$24.98 EACH
SAVE $5
Lepai LP-2020BT Bluetooth Hi-Fi Audio Mini Class D Stereo Amplifier FM Media with Power Supply
