  • 10A Variac 0-130 VAC SC-10T-2 with Digital Display and Twin Output
NEW 10A Variac 0-130 VAC SC-10T-2 with Digital Display and Twin Output
Part #120-845
Part #120-845
Model: SC-10T-2
An essential component of any test bench, a variable transformer allows the user to adjust incoming 110/120 VAC to 0~130 VAC via a dial.
  • Easy operation by the knob on top of the unit
  • Digital meter makes it easy to see output voltage
  • 10A current capacity for large loads
NEW $210.98
MSRP: $249.99
Save $39.01 (16%)
A variable transformer is an extremely handy device that allows the user to dial 110/120 VAC wall voltage up or down from 0~130 VAC, measured by a meter on the front of the unit.
Most often, variable transformers are used on test benches, either to troubleshoot problems, test experimental circuits, or slowly power up vintage electronics to evaluate and perhaps recondition aging internal components.
They're also used in performing arts and cinematography to control lighting. In areas where line voltage runs higher than standard, use of a variac can improve the function and longevity of electronics.
• Current capacity: 10A • Dimensions: Overall diameter: 6-3/4"; Overall width including power switch, digital, meter and outlet: 8"; Overall height including knob: 8".
ModelSC-10T-2
Part Number120-845
UPC848864077734
Weight21
    MONSTER DEAL
    OF THE WEEK
    $98.98 EACH
    SAVE 40%
    Dayton Audio DTA-PRO 100W Class D Bluetooth Amplifier with USB DAC IR Remote and Sub Output
