  • CAIG D5S-6-LMH DeoxIT Spray 5 oz. Original Can
CAIG Laboratories
Part #349-230
CAIG Laboratories
Part #349-230
Model: D5S-6-LMH
CAIG DeoxIT D5S-6 is a fast-acting deoxidizing solution that cleans, lubricates, and improves conductivity on all metal connectors and contacts. Routine treatment seals and protects all electrical connections. Its proven formula reduces intermittent failures, arcing, wear, and abrasion in potentiometers, switches, and other electrical components.
  • Cleans, lubricates, and protects connectors and contacts
  • Ensures the maximum performance of electronic audio and video equipment
  • Reduces arcing, RFI, wear, and abrasion
  • Helps restore conductivity and reduces intermittent connections
  • Environmentally safe, non-ozone depleting
  • Unique three position classic spray nozzle for variable pressure options
Your Price: $17.99
MSRP: $23.95
Save $5.96 (25%)
979In Stock
CAIG DeoxIT is a must have for preserving and lubricating connectors, but also improves conductivity of contacts. If the metal surface is discolored and the corrosion is severe, DeoxIT dissolves the contamination and protects the surface. Not only does DeoxIT remove corrosion, it also seals and protects all electrical connections, and reduces intermittent failures, arcing, wear, and abrasion. Temperature range: -34° C to 200° C. Provides light 5% coating. Flammable (until solvent evaporates). Propellant contains no ozone-depleting CFCs.
The included straw works with the three position variable pressure spay nozzle to deliver the right amount of DeoxIT into areas normal spray cans can't reach.
BrandCAIG Laboratories
ModelD5S-6-LMH
Part Number349-230
UPC697429002540
Weight0.45
MONSTER DEAL
OF THE WEEK
$98.98 EACH
SAVE 40%
Dayton Audio DTA-PRO 100W Class D Bluetooth Amplifier with USB DAC IR Remote and Sub Output
