  • 1.3mm x 3.5mm Metal Panel Mount DC Coax Barrel Power Jack
Part #090-5021
Part #090-5021
Use this metal housed 1.3 x 3.5 mm DC coax jack, which mounts in a small 0.313" hole, for smaller DIY projects with limited internal space or to replace worn out jacks.
  • Mounts in small 0.313" hole for limited internal space projects
  • All metal housing for durability
Your Price: $2.47
MSRP: $3.99
Save $1.52 (38%)
Quantity:Qty: 1-9 $2.47/ea
Quantity:Qty: 10+$2.22/ea
16In Stock
This 1.3 x 3.5 mm DC jack works perfect in small portable speaker or other audio projects. It is the same size jack that the original Google Home and Amazon Echo uses. The jack's 0.313" mounting hole and 0.75" total depth, including terminals, enables it to fit in small smart or portable speaker projects. The durable metal housing holds up to the abuse that portable projects dish-out. Long rear terminal connects to the tip and the smaller rear terminal is another ground that connects to the barrel when a plug is inserted for tip positive plolarity.
Part Number090-5021
UPC848864056999
Unit of MeasurePackages
DC Power Connector TypeJack
MONSTER DEAL
OF THE WEEK
$98.98 EACH
SAVE 40%
Dayton Audio DTA-PRO 100W Class D Bluetooth Amplifier with USB DAC IR Remote and Sub Output
