  • Replacement Google Home 16.5V 2.5A DC Power Supply AC Adapter 1.35 x 3.5mm Center Positive (+) Plug
CLEARANCE Replacement Google Home 16.5V 2.5A DC Power Supply AC Adapter 1.35 x 3.5mm Center Positive (+) Plug
Part #120-067
Part #120-067
Looking for a replacement adapter for your Google Home? Your search ends with the 16.5 VDC 2.5A AC Adapter. The key feature of this adapter is its switch mode power supply, which helps in delivering constant current to your Google Home.
  • 2.5A current capacity ensures optimal performance
  • Switching power supply provides constant current and prevents unwanted noise
  • Replaces part #W16-033n1a
  • Meets the USA level VI standby power requirements
  • UL listed for improved safety
CLEARANCE $9.98
MSRP: $21.99
Save $12.01 (55%)
18In Stock
Performance and efficiency make a harmonious combo in the 16.5 V 2.5A AC adapter. The switching power supply of this replacement adapter delivers constant current and averts unwanted noise. Featuring a current capacity of 2.5A, this UL listed adapter performs exceptionally well when compared to conventional adapters. This 2.5A AC adapter is the perfect replacement for the original Google Home adapter.
Specifications: • Output voltage: 16.5 V @ 2.5A • Input voltage: 100-240 VAC @ 50/60 Hz • Cord length: 6 ft. with 1.35 mm x 3.5 mm x 12 mm center positive plug • Dimensions: 1.29" D x 1.84" W x 3.61" H (32.7 x 46.6 x 91.5 mm) without cord and AC prongs.
Part Number120-067
UPC848864051710
Weight0.4
Center/Tip PolarityCenter Positive
Current Capacity2500mA
DC Output Voltage16V
Input Voltage100~240 VAC
Plug Size1.35 x 3.5 mm
MONSTER DEAL
OF THE WEEK
$45.98 EACH
SAVE $12
Dayton Audio KABD-250 2 x 50W All-in-one Amplifier Board with DSP and Bluetooth 5.0 aptX HD
