  • miniDSP 4x10 Hd 2 Analog In 8 Analog Out + 2 Digital In/Out DSP
CLEARANCE miniDSP 4x10 Hd 2 Analog In 8 Analog Out + 2 Digital In/Out DSP
miniDSP
Part #230-338
miniDSP
Part #230-338
Model: miniDSP 4x10 Hd
The miniDSP 4x10 Hd customizes the sound of a speaker system to suit your preferences. The 4x10 Hd combines high quality audio algorithms along with flexible software, following in the footsteps of miniDSP's successful line of processors. Taking full advantage of the processing power of this unit takes your sound system to a whole new level of accuracy.
  • 24 bit ADC/DAC for great sound quality, and a low noise floor
  • 28/56-bit DSP engine offers a large amount of processing power
  • Learning IR control feature
  • Room correction utilizing FIR filters
  • No computer required once configured
The 4x10 Hd features balanced & unbalanced audio I/O, on a platform that easily fits the needs of most audio systems. The appealing powder coated steel enclosure, brushed aluminum front panel, and removable rack ears are an ideal match for both consumer or commercial installations. The software included with the 4x10 Hd is compatible with both Windows and Mac OS.
On the processing side, the miniDSP is able to utilize audio plug-ins to make it an extremely versatile processor. The 4x10 Hd is easily configured on Mac/PC machines from a responsive and intuitive Graphic User Interface. Once the unit is programmed, control of presets, master volume and digital source selection can be done via the front panel encoder or infrared (IR) receiver without the use of a computer.
Adding a miniDSP isn’t just installing another audio product, it’s about joining the ranks of a large audio community with fully integrated tools and extensive application notes.
What's Included:
  • 1 x MiniDSP 4x10 HD processor with removeable rackmount ears
  • 1 x 12VDC universal power supply. IEC type removable plug
  • 1 x Shielded USB cable (1.5m)
  • 1 x Toslink audio cable
  • Specifications:
    Digital Signal Processor Engine:Analog Devices Fixed point DSP
    Internal Processing resolution & Sample Rate:28/56 bit / 48~96 kHz
    Input/Output Configuration:4 in / 10 out
    Audio Input Connectivity:
    Stereo Digital Inputs: AES-EBU (XLR), SPDIF (RCA) Toslink (optical)2x Balanced (Phoenix Terminal Block)
    2x Unbalanced (RCA) inputs 114 dB ADC IC
    Measured SNR 105 dB
    Audio Output Connectivity:Stereo Digital Outputs: AES-EBU (XLR), SPDIF (RCA) Toslink (optical)
    8x Balanced (Terminal Block)
    8x Unbalanced (RCA) outputs 114 dB DAC IC
    Measured SNR 105 dB
    Input/Output Max Levels:IN: Unbalanced: 2 Vrms / .9 Vrms
    Balanced: 4 Vrms
    Input Impedance:Unbalanced: 10 k? / Balanced 100 k?
    Output Impedance:Unbalanced: 560 ? / Balanced: 1.12 k?
    Calibration Software:miniDSP 4x10 plug-in / miniDSP 10x10 plug-in
    Filtering Technology:IIR
    DSP Presets:Up to 4 presets
    Power Input:External 12V, 2.1 A supply
    Dimensions:1.63" x 16.9" x 9.9" (41.5 x 429 x 252 mm) - 1RU height
    BrandminiDSP
    ModelminiDSP 4x10 Hd
    Part Number230-338
    UPC848864050973
    Weight11.35
    MONSTER DEAL
    OF THE WEEK
    $98.98 EACH
    SAVE 40%
    Dayton Audio DTA-PRO 100W Class D Bluetooth Amplifier with USB DAC IR Remote and Sub Output
