  • Yamaha NS-SW100 10" 100 Watt Powered Subwoofer
Yamaha
Part #312-646
Yamaha
Part #312-646
Model: NS-SW100
Expect rich and powerful bass with the Yamaha NS-SW100 10" subwoofer. Employing a number of Yamaha high-performance bass technologies and discrete amp circuitry, the unit will surely give your music and soundtracks the low end response you have been looking for.
  • 10" cone woofer for deeper lows
  • New Twisted Flare Port to provide a tight and clean bass response
  • Employs YST II (Yamaha Active Stereo Technology II) to maintain accurate low end reproduction
  • Sleek and stylish box design to fit in any room
Your Price: $199.95
Improved Bass Response
Using a gently twisting flared shape for the port causes smooth air flow around the port and reduces the noise that the port can cause. A conventional port produces turbulent air flow that creates extra noise not present in the original input signal. The result of the Twisted Flare Port is a clear, tight, and realistic low frequency response.
Stable and Accurate Low End
Developed by Yamaha, YST II (Yamaha Active Stereo Technology II) combines negative-impedance and constant current principles to drive the cone with precise control. A more stable and accurate low end representation is achieved through YST II. Advanced Negative Impedance Converter (ANIIC) circuits help maintain excellent linearity to produce higher sound quality. With all of these technologies combined the end result is a subwoofer that is clean, tight, and reproduces the low end signal accurately.
Driver: 10" cone • Dynamic power: 100 watts (5 ohms) • Output power: 50 watts (100 Hz, 5 ohms, 10%THD) • Frequency response: 25 Hz – 180 Hz • Advanced YST: Yes • Twisted Flare Port: Yes • Dimensions: 13.88"W x 13.88"H x 16.13"D.
BrandYamaha
ModelNS-SW100
Part Number312-646
UPC027108954479
Weight30.15
Woofer Diameter10"
