  • Dayton Audio BS36 36" LCR Speaker Bar Black
Dayton Audio
Part #300-684
Dayton Audio
Part #300-684
Model: BS36
The small-but-mighty Dayton Audio BS36 sound bar speaker bar combines left, center, and right channel speakers into a single convenient mountable enclosure. The BS36 can be positioned above or below your flat screen TV, or sit freestanding on your home theater cabinet.
  • Great for any plasma or LCD TV installation
  • Ideal for space-limited home theater applications
  • Connects to any home theater receiver via separate left, right, and center speaker inputs
  • High-gloss black lacquer finish
  • Position on any flat surface or mounts easily to the wall
Your Price: $229.98
MSRP: $299.99
Save $70.01 (23%)
The Dayton Audio BS36 LCR soundbar speaker bar uses long-excursion woofers for superb dynamic impact and bass extension, unlike the thin-sounding speakers built into HDTVs. When the BS36 is combined with a pair of SAT-BK satellite speakers and a powered sub like the Dayton Audio SUB-80, you'll have created a spacious-sounding yet compact-sized surround sound experience that will impress family and friends.
The BS36 LCR speaker bar is easy to install, and the beautiful hand rubbed black lacquer finish will turn a Steinway piano green with envy! Each speaker bar is packaged with a pair of rubber speaker feet for tabletop mounting.
Specifications: • Three 3-3/4" paper cone woofers • Three 5/8" aluminum tweeters • Power handling: 50 watts RMS/80 watts max • Impedance: 8 ohms • Frequency response: 100-20,000 Hz • SPL: 87 dB 1W/1m • Dimensions: 4-3/4" H x 36" W x 4-1/4" D. Note: Screw mounts and M5 threaded inserts are designed for 16" on-center studs. Hardware sold separately. See related items for optional Hangman mounting bracket.
ModelBS36
Part Number300-684
UPC844632064739
Weight14.2
ColorBlack
ConfigurationMTM / LCR
Input Rating8 ohm
Woofer Diameter3.75"
MONSTER DEAL
OF THE WEEK
$98.98 EACH
SAVE 40%
Dayton Audio DTA-PRO 100W Class D Bluetooth Amplifier with USB DAC IR Remote and Sub Output
