  • Wavecor TW030WA11 30mm Semi Horn Loaded Textile Dome Tweeter with Rear Chamber 4 Ohm
Wavecor
Part #298-1120
Wavecor
Part #298-1120
Model: TW030WA11
The Wavecor TW030WA11 is a 30 mm tweeter with an integrated waveguide. This tweeter is designed for the most demanding applications, where low resonant frequency, high sensitivity, power handling, controlled dispersion, and a very wide frequency range are required.
  • Waveguide face plate for controlled dispersion, offering optimized off-axis and power response
  • 30 mm voice coil design with high power handling, and low resonance frequency
  • Precision-coated textile diaphragm for improved consistency and high-frequency extension
  • Copper clad center pole yielding very low voice coil inductance for reduced distortion and increased high frequency output
  • Flexible lead wires for higher power handling and larger excursion
  • Gold plated terminals to prevent oxidation and ensure long-term reliable connection
  • Vented voice coil former for reduced distortion and compression
Your Price: $87.00
Estimated back in stock 3/14/2025
Alert Me When Available
The high power handling of this tweeter makes the TW030WA11 a natural candidate for high-end 2-way speaker systems.
BrandWavecor
ModelTW030WA11
Part Number298-1120
UPC848864054612
Weight1.55
Cone / Dome Diameter1.125"
Cutout Diameter4.13
Tweeter TypeSoft Dome
Power Handling (RMS)45 Watts
Frequency Response1,500 to 25,000Hz
Sensitivity93.5dB 2.83V/1m
Resonant Frequency (Fs)410Hz
DC Resistance (Re)3.5Ω
Voice Coil Inductance (Le)23mH
Mechanical Q (Qms)1.9
Electromagnetic Q (Qes)1.34
Total Q (Qts)0.79
Overall Outside Diameter4.53"
Depth2.24"
MONSTER DEAL
OF THE WEEK
$98.98 EACH
SAVE 40%
Dayton Audio DTA-PRO 100W Class D Bluetooth Amplifier with USB DAC IR Remote and Sub Output
