Wavecor SW146WA01 5-3/4" Balanced Drive Paper Cone Subwoofer 4 Ohm
Wavecor
Part #298-1048
Wavecor
Part #298-1048
Model: SW146WA01
The Wavecor SW146WA01 is a 5-3/4" high-performance subwoofer that utilizes balance drive motor technology. The SW146WA01 is ideal in compact 3-way designs as a low frequency driver.
- Balanced Drive motor structure for optimal drive force symmetry resulting in largely reduced even order harmonic distortion
- Rigid paper cones to ensure piston motion even at high levels - for reduced distortion
- Rigid steel chassis’ with extensive venting for lower air flow speed reducing audible distortion
- Built-in aluminum field-stabilizing rings for reduced distortion at high levels
- Conex spider for better durability under extreme conditions
- Delivered with foam gasket attached for hassle-free mounting and secure cabinet sealing
- Gold plated terminals to ensure long-term trouble free connection
