  • Visaton FR 10-8 4" Full-Range Speaker
Visaton
Part #292-513
Visaton
Part #292-513
Model: FR10-8
Visaton's FR10-8 full-range 4" dual-cone speaker offers great frequency response and sensitivity in a compact package. Great for point-source, single-driver speakers. 8-ohm impedance.
  • Smooth response from 80 to 20,000 Hz for true full range performance
  • Perfect for use in open and infinite baffle designs
  • Dual cone design delivers perfect time alignment and great off-axis response
  • Common size make this an excellent replacement driver for many applications
Your Price: $14.52
MSRP: $18.99
Save $4.47 (24%)
Quantity:Qty: 1-9 $14.52/ea
Quantity:Qty: 10-24 $14.09/ea
Quantity:Qty: 25+$13.49/ea
46In Stock
The FR10-8 4" dual cone full-range speaker from Visaton provides uniform frequency response and a surprising amount of low-frequency output. The 0.67 Qts motor is designed to offer optimal bass response when used in infinite baffle and open back applications, such as automotive car door speakers, ceiling and wall mounted speakers, and is perfect for use in open baffle designs. The whizzer cone design offers seamless time alignment when compared to multi-way speakers and provides superior off-axis performance.
BrandVisaton
ModelFR10-8
Part Number292-513
Weight0.9
Nominal Diameter4"
Bolt Circle Diameter4.5
Power Handling (RMS)30 Watts
Power Handling (MAX)50 Watts
Frequency Response80-20,000Hz
Sensitivity86dB 2.83V/1m
Voice Coil Diameter0.75"
Resonant Frequency (Fs)90Hz
DC Resistance (Re)7.2Ω
Voice Coil Inductance (Le)0.2mH
Mechanical Q (Qms)2.29
Electromagnetic Q (Qes)0.95
Total Q (Qts)0.67
Compliance Equivalent Volume (Vas)0.081ft³
Mechanical Compliance of Suspension (Cms)0.648mm/N
BL Product (BL)4.6T·m
Diaphragm Mass Inc. Airload (Mms)5.7g
Surface Area of Cone (Sd)50cm²
Cone MaterialPaper
Surround MaterialCloth
Overall Outside Diameter4.13"
Baffle Cutout Diameter3.6"
Depth1.85"
Sealed Volume0.16ft³
Sealed F3107.2Hz
Vented Volume0.16ft³
Vented F371.8Hz
