  • TriTrix MTM Speaker Kit Pair with Knock-Down Cabinets
Part #300-7128
Part #300-7128
The TriTrix MTM speaker kit is hailed by DIYers as one of the best reasons to build your own! Never before has a speaker kit made such an impact in the DIY speaker building community. Designed by Curt Campbell, the TriTrix MTM set standard for performance on a budget.
  • Delivers a natural relaxed sound with flat smooth response
  • Compact ported enclosure design for extended bass response
  • CNC cut MDF cabinet panels make the enclosure easy to assemble with minimal tools
  • Designed and tuned by well-known speaker designer Curt Campbell
  • Save over $85 off the normal retail price when you purchase this kit
Your Price: $289.98
MSRP: $424.99
Save $135.01 (32%)
The TriTrix MTM vented speaker kit is a compact design that delivers high performance full range audio without breaking the bank. With an F3 in the low 50's and an F10 of 40 Hz, you can expect solid low end from the modest sized enclosures. The TriTrix is known for its smooth frequency response and its ability to make even poor recordings sound great. Thanks to the paper cone woofers and soft dome tweeter, this speaker delivers natural response with an easy to listen to sound. This kit includes nearly everything you need to build a pair of top-notch speakers in no time flat, including: a knock-down enclosure, drivers, damping material, and crossover components.
Features:
Customer Comments:
"Simply unbelievable. The detail and imaging is  mind-blowing" - Ryan ⋆⋆⋆⋆⋆
"They sound fantasic and I’m shocked by the  amount of bass..."- Peter M.  ⋆⋆⋆⋆⋆
"These sound better than many pre-assembled  speakers in $300 dollar range." -Exporter ⋆⋆⋆⋆⋆
"First time building diy speakers. Had a lot of fun  with my 11 year old son." -Lourenço C ⋆⋆⋆⋆⋆
Customer Projects:
                 The Cabinet
The solid MDF enclosure panels are all CNC milled to tight tolerances ensuring easy assembly and feature a 3/4" thick front baffle. The knock-down enclosures includes 2 center braces tying all sides together to minimize cabinet resonances. Recesses for flush mounting the drivers and the opening for the port are pre-cut making assembly a snap.
                                                  The Tweeters
The Dayton Audio DC28FS-8 was chosen for the high frequencies. This was an easy choice, the DC28FS-8 offers superior European design and performance at a fraction of the cost of similar audiophile high frequency transducers.
The Woofer
When Curt Campbell was designing the TriTrix he searched for drivers that would offer the best bang for the buck. For the woofer Curt selected the Dayton Audio DC130BS-4 5-1/4" Classic Series. With impressive bass performance and smooth overall response, this is one of our most popular woofers.
Kit Components:
Part #QTY.Description
295-3024Dayton Audio DC130BS-4 5-1/4" Classic Shielded Woofer 4 Ohm
275-075
2Dayton Audio DC28FS-8 1-1/8" Silk Dome Shielded Tweeter
255-2702Jantzen 1088 2.5mH 18 AWG Air Core Inductor
255-2342Jantzen 1951 0.60mH 18 AWG Air Core Inductor
027-4282Dayton Audio DMPC-10 10uF 250V Polypropylene Capacitor
027-4362Dayton Audio DMPC-20 20uF 250V Polypropylene Capacitor
004-2.42Dayton Audio DNR-2.4 2.4 Ohm 10W Precision Audio Grade Resistor
260-3872Port Tube 2" ID Adjustable
260-520
2Sonic Barrier 1/2" Acoustic Foam w/PSA 18" x 24"
Note: Crossover components may be substituted with parts of equal or higher quality depending on available inventory. Screws, binding posts, and speaker wire are not included.
  • Power:  70 watts RMS/140 watts max
  • Frequency response: 45-20,000 Hz
  • Impedance: 8 Ohm
  • Sensitivity:  88 dB 1W/1m
  • Dimensions: 18.5" H x 7.5" W x 11.5" D
ModelTritrix MTM
Part Number300-7128
UPC848864033976
Weight41.83
Cabinet Dimensions (HxWxD)18.5" x 7.5" x 11.5"
Cabinet OptionsUnfinished/Unassembled
ColorUnfinished
Configuration2-way MTM
Input Rating8 ohm
Speaker TypeBookshelf
Woofer Diameter5.25"
