  • Sure Electronics AA-AK11231 Class AB 10W Mono Power Amplifier Kit TDA2030
CLEARANCE Sure Electronics AA-AK11231 Class AB 10W Mono Power Amplifier Kit TDA2030
Sure Electronics
Part #320-336
Sure Electronics
Part #320-336
Model: AA-AK11231
This small, easy-to-assemble mono audio amplifier kit's Class-AB design provides up to 10 watts of pristine, accurate audio reproduction combined with an authoritative bass punch. Designed for use with 4.5 to 25 VDC power supplies (available separately).
  • Small, mono amplifier kit
  • Great kit for beginners
  • Supplies up to 10W of clean, clear power
  • Designed to work with 4.5 to 25 VDC power supplies (sold separately)
CLEARANCE $8.98
MSRP: $15.99
Save $7.01 (44%)
26In Stock
This Class-AB mono audio amplifier kit incorporates the TDA2030 power amplifier IC to deliver pristine, accurate audio reproduction combined with an authoritative bass punch, all in a small, hand-held sized package.
Assembly is accomplished in minutes, due to the easy to mount and solder through-hole components. Able to be powered by a wide voltage range of 4.5 to 25 VDC, this amplifier can suit a wide range of applications: active speakers, mini subwoofers, even mobile audio applications. Power supply not included.
Includes:
• PCB (L x W): 2-7/16" x 1-7/8"
• One TDA2030 amplifier IC
• Resistors:
One 680Ω (blue, gray, red, gold stripes)
One 4.7Ω (yellow, red, orange stripes)
One 4.7 kΩ (yellow, purple, red, gold stripes)
Four 22 kΩ (red, red, orange, gold stripes)
• Capacitors:
Three  470 μF, 35V electrolytic (black, white stripe indicates negative lead)
Four 22 μ  35V electrolytic (black, white stripe indicates negative lead)
Four 1 μF monolithic (small yellow, non-polarized)
• One green LED
• One heatsink
• Three screws (two for mounting the heatsink to the PCB, one for mounting the IC to the heatsink)
• One screw nut (for securing the IC to the heatsink)
BrandSure Electronics
ModelAA-AK11231
Part Number320-336
UPC848864001852
Weight0.15
Project Kit TypeAmplifiers & Audio
