  • Sanus SF34B Foundations 34" Steel Speaker Stand Pair Black
CLEARANCE Sanus SF34B Foundations 34" Steel Speaker Stand Pair Black
Sanus
Part #240-806
Sanus
Part #240-806
Model: SF34-B1
The Foundations Steel Series SF34 is a 34" stand for small-to-medium bookshelf speakers up to 25 lbs.
  • Adjustable carpet spikes and rubber feet add stability on any surface
  • Heavy-gauge steel construction provides extreme rigidity and stability
  • Large integrated wire path organizes heavy-gauge cables
  • Provides safe and secure bolt-mounting for many of today's speakers
The Foundations Steel Series SF34 is a 34" stand for small-to-medium bookshelf speakers up to 25 lbs. Its extra-large steel base includes optional carpet spikes for superior stability on any surface. Twin heavy-gauge steel pillars feature a concealed wire path and resonance damping rings, and they can be filled with sand or shot for added mass. The 6" by 6.5" top plate offers adjustable brass studs and neoprene pads for speaker alignment.
Specifications: • Dimensions: 11.75" W x 34" H x 14.75" D (29.85 x 86.36 x 37.47 cm) • Maximum speaker weight: 25 lbs. (11.36 kg).
BrandSanus
ModelSF34-B1
Part Number240-806
UPC793795523549
Weight36
