  • SMH SY175 Series 4 AWG 175A Breakaway DC Power Connector
SMH
Part #263-120
SMH
Part #263-120
Model: SY6325G6
The SMH SY6325G6 battery connector is designed for use as a power quick-disconnect in automotive, RV, and marine applications, as well as other high-current DC charging circuits.
  • 4 AWG battery connector kit rated at 175A, 600 VDC
  • Impact resistant polycarbonate housing offers high physical strength and superior dielectric properties
  • Silver-plated solid copper contacts offer low resistance for superior conductivity
  • Self cleaning contact design resists arcing by keeping conductive surfaces clean and free of corrosion
  • Contacts have flared and heat treated barrels which readily accept fine stranded wire
  • Integral stainless steel springs maintain constant pressure on the contact to insure a consistent, low-resistance connection
  • Note: Assembly includes one housing and two tips (contacts)
Your Price: $17.90
Quantity:Qty: 1-3 $17.90/ea
Quantity:Qty: 4+$16.80/ea
Order in the next 1 hr 17 min to ship today. Details
73In Stock
SMH high-current breakaway DC battery connectors are perfect for use as a quick disconnect for car audio amplifier power, RV and marine applications, and other high-current DC charging circuits. Underwriters Laboratories recognizes compatibility of SY Series battery connectors with Anderson Power Products SB® Series connectors. Requires two pieces for operation, sold individually. Dimensions: 3.13" L x 2.19" W x 1.0" H. SMH #SY6325G6.
  • UL amperage*/voltage rating: 175 amps/600 VDC
  • Operating temperature range: -20° to 105° C
  • Current rating*: 175 amps on 1/0 AWG wire produces 30° C rise
  • Insulation with standing test voltage (volts, dc): 2200dc
  • Maximum wire insulation diameter: 0.75"/19 mm
  • Average contact retention force: Approximately 300 lbs.
  • Average contact resistance: With 1-3/4" (45 mm) of 1/0 AWG wire 100 µΩ
  • Vibration resistance: Excellent
  • Mating cycles: 10,000 / For disconnect use only
  • Impact resistance: High
  • Environmental restrictions: Protected-no hydrocarbon fluids
  • Flammability Rating: UL94V-0
  • Average mating and unmating force: 25 lbs (11.25 kg)
* For largest wire or cable size
• Recognized under the component program of Underwriters Laboratories, Inc. File No. E81817
• Listed by Canadian Standards Association for use with certified equipment. File No. LR82704
BrandSMH
ModelSY6325G6
Part Number263-120
UPC844632034480
Weight0.32
