Rolls BD87 Bluetooth Audio Adapter
- Professional Bluetooth adapter for streaming audio in audio systems
- Multiple, versatile output options are flexible for both residential and commercial applications
The Rolls BD87 Bluetooth audio adapter converts any Bluetooth signal to analog for use in non-Bluetooth audio systems. Designed for both residential and commercial installations. The adapter features balanced mic level XLR, stereo RCA, and 1/8" line level outputs providing easy integration into any existing system. A dedicated level control gives you the ability to adjust audio output. When powered off the BD87 will remember the device it was previously paired with and search for that device when powered on. The adapter is also easy to reset making it quick and simple to pair with other devices.
• Outputs: Stereo RCA and 1/8", mono XLR mic level
• Output impedance: 1 kohm RCA & 1/8", 600 ohm XLR
• Power requirements: 15 VDC, 500 mA
• Chassis: Powdered coated steel
• Dimensions: 3.25" x 3" x 1.5"
Product Details | |
Brand | Rolls |
Model | BD87 |
Part Number | 245-031 |
UPC | 675889008708 |
Unit of Measure | Each |
Weight | 0.95 |
