Rean NYS207 1/4" Mono Slim Right Angle Phone Plug
- 1/4" mono slim right angle phono plug
- Make your own cables to the perfect length
- Rugged construction
- Nickel plated brass plug
Quantity:Qty: 1-24 | $1.39/ea |
Quantity:Qty: 25-99 | $1.35/ea |
Quantity:Qty: 100+ | $1.30/ea |
We'll send you an email when Rean NYS207 1/4" Mono Slim Right Angle Phone Plug is back in stock or available for preorder.
Commercial 1/4" mono slim right angle plug features a turned brass handle with nickel plating, a larger-than-typical crimp cable clamp, and oversized solder tabs. The precise machined one-piece tip contact without rivets makes it unique and avoids hook up in a socket or break off the tip.
Specifications: • Connector type: 1/4" mono slim right angle plug (2 pole) • Handle: PVC plastic • Accepts cable O.D. up to 6 mm • Mfg. #NYS 207.
REAN — a brand of Neutrik AG
Product Details | |
Brand | Rean |
Model | NYS207 |
Part Number | 092-1616 |
Unit of Measure | Each |
Weight | 0.05 |
Product Specifications | |
Conductors | Mono TS |
Gender | Male / Plug |
Mounting Type | Cable Mount |
