  • Pyramid PS3KX 13.8 V 2.5A DC Power Supply
Pyramid
Part #120-530
Pyramid
Part #120-530
Model: PS3KX
This regulated power supply features binding posts for simple and secure hookup. It's perfect for powering 12 VDC devices that draw up to 2.5 amps.
  • Electronic overload with auto reset and short circuit protection
  • Built-in cooling fan
  • Hassle-free screw terminal connectors
  • Linear/regulated power supply design
  • Illuminated on/off switch for power on notification
  • Rugged & durable housing construction
Your Price: $36.98
Order in the next 3 hr 27 min to ship today. Details
The Pyramid bench power supply makes for a great addition to any hobbyist work desk or equipment testing station. It provides convenient and reliable AC-to-DC power performance needed by 12 V devices or projects that draw less than 2.5A. The built-in electronic overload and short-circuit protection, with auto reset, ensure safe operation and the illuminated power switch alerts you to power-on status. The heavy duty case holds up to bench type work and the universal hardwired screw-type terminals ensure hassle-free connection and are compatible with a wide range of components. Built-in fan keeps the power supply cool.
Specifications: • Output voltage: 13.8 V (fixed) • Output current: 2.5 amps (continuous), 3 amps (surge) • Ripple voltage: Less than 150mV RMS at rated output • Input voltage: 105-125 VAC, 60Hz • Dimensions: 7.5" L x 4.9" W x 3" H • Net weight: 2.75 lbs.
BrandPyramid
ModelPS3KX
Part Number120-530
UPC068888701556
Weight4
DC Output Voltage13.8V
Input Voltage120 VAC
MONSTER DEAL
OF THE WEEK
$98.98 EACH
SAVE 40%
Dayton Audio DTA-PRO 100W Class D Bluetooth Amplifier with USB DAC IR Remote and Sub Output
