  • True RMS Digital Multimeter with Bluetooth 4.0 Android and iOS Compatible
Part #390-737
Part #390-737
This versatile Bluetooth 4.0 multimeter syncs to a smart phone and verbally speaks the reading that's on the B35T's large backlit display. The free app also enables a mobile device to store data and remotely control the B35T.
  • Three main functions include data logger, multimeter, and temperature meter
  • Smart voice-reading accessible when display can't be seen
  • Large 3" backlit display includes a simulated bar chart for quick readings
  • True RMS reading for accuracy
  • Includes carry case, alligator clips, and plug-in diode adapter
  • Uses two AA batteries not included
Your Price: $99.98
Bench testing or field testing is a perfect fit for the B35T. Many times when testing outlets, live wires, or components on a PC board keeping the probes in the right spot and reading the display is almost impossible. Download the free Owon Multimeter BLE4.0 app to a smart phone and solve this age old problem. The meter will speak the value of the reading through a mobile device using Android 4.3 or above / iOS 7.0 or above OS. The large backlit 3" (5/6) digit 6,000 count full scale display is always available when a mobile device is not around.
Mute the voice when it's not needed and use the meter to save readings to a mobile device over a certain time period. Clamp the test leads to a component that needs testing and walk away from the meter. The mobile app enables you to control the meter up to 30 feet away. Choose the setting on the smart phone screen and the meter will continually read out values and save them to the mobile device. If needed, this app will let two meters sync to one smart phone and display the values side-by-side.
• LCD screen size: 69mm x 52mm
• Max. Display: 6000 Count
• DC Voltage: 60.00 mV / 600.0 mV / 6.000V / 60.00V / 600.0V / 1000V
• AC Voltage: 60.00 mV / 600.0 mV / 6.000V / 60.00V / 600.0V / 750.0V
• DC Current: 600.0 uA / 6.000 mA / 60.00 mA / 600.0 mA / 6.000A / 20.00A
• AC Current: 600.0 uA / 6.000 mA / 60.00 mA / 600.0 mA / 6.000A / 20.00A
• Resistance: 600.0 ohm / 6.000 Kohm / 60.00 Kohm / 600.0 Kohm / 6.000 Mohm / 10.00 Mohm / 60.00 Mohm
• Frequency: 9.999 Hz / 99.99 Hz / 999.9 Hz/ 9.999 kHz / 99.99 kHz / 999.9 kHz / 9.999 MHz
• Capacitance: 40.00 nF / 400.0 nF / 4.000 uF / 40.00 uF / 400.0 uF / 4000 uF
• Temperature: -58 - 752° F (-50 - 400° C)
• Dimensions: 7.28" x 3.35" x 1.18"
• Weight: 11.29 oz.
• Batteries: 2 x AA not included
Package includes:
• Multimeter
• Cloth bag with zipper
• Two test leads
• One pair of alligator clips
• K-type thermocouple
• Plug in adapter for diode and capacitor test
• Manual
Part Number390-737
UPC848864033037
Weight1.25
MONSTER DEAL
OF THE WEEK
$189.00 EACH
SAVE 21%
Dayton Audio SPA250DSP 250W Subwoofer Plate Amplifier with DSP
