  • Precision Port 6" Flared Port Tube Kit
Precision Sound
Part #268-354
Precision Sound
Part #268-354
Model: PSP6-BKNT
The unique flared-end construction of the Precision Port™ system enables it to outperform any standard port tube on the market. Conventional tubes suffer from nasty turbulence at the entrance and exit of the port, producing unwanted noise and poor sound quality.
  • Gives your enclosures a sleek, professional look
  • Reduces air turbulence to minimize or eliminate port noise
  • Just cut to length, glue together, and install
  • Mounts in 8-1/4" diameter cutout
  • Create a port up to 17" long
Your Price: $56.18
MSRP: $72.99
Save $16.81 (23%)
Quantity:Qty: 1-3 $56.18/ea
Quantity:Qty: 4+$53.50/ea
Estimated back in stock 3/8/2025
Alert Me When Available
The unique flared-end construction of the Precision Port™ system enables it to outperform any standard port tube on the market. Conventional tubes suffer from nasty turbulence at the entrance and exit of the port, producing unwanted noise and poor sound quality. The Precision Port™ system overcomes these problems and as a result can actually produce a gain of up to 3 dB in output! Now you can experience good looks, low distortion, and superior overall sound quality thanks to the Precision Port™ system. Convenient front screw holes make this tube easier to install than others on the market. Create a port up to 17" long, then glue with ABS glue found at any hardware store. Installation instructions included. Dimensions: • 9-1/4" outside and inside flare outer diameter • 8-1/4" cutout. Also available in 2", 3", and 4" diameters. Proudly designed in the USA.
To calculate the proper port length for your cabinet and tuning, use Precision Sound Products' Port Length Calculator.
BrandPrecision Sound
ModelPSP6-BKNT
Part Number268-354
UPC844632067297
Weight3.35
MONSTER DEAL
OF THE WEEK
$23.98 EACH
SAVE 20%
Lepai LP-2020BT Bluetooth Hi-Fi Audio Mini Class D Stereo Amplifier FM Media with Power Supply
