  • Precision Port 3" Flared Speaker Cabinet Port Tube Kit
Precision Sound
Part #268-350
Precision Sound
Part #268-350
Model: PSP3-BKHT
The unique flared-end construction of the Precision Port™ system enables it to outperform any standard port tube on the market. Conventional tubes suffer from nasty turbulence at the entrance and exit of the port, producing unwanted noise and poor sound quality.
  • Reduces air turbulence to minimize or eliminate port noise
  • Gives your enclosures a sleek, professional look
  • Just cut to length, glue together, and install
  • Mounts in 5-1/4" diameter cutout
  • Create a port up to 17" long
Your Price: $19.13
MSRP: $24.99
Save $5.86 (23%)
Quantity:Qty: 1-3 $19.13/ea
Quantity:Qty: 4+$18.21/ea
Estimated back in stock 1/31/2025
Alert Me When Available
The unique flared-end construction of the Precision Port™ system enables it to outperform any standard port tube on the market. Conventional tubes suffer from nasty turbulence at the entrance and exit of the port, producing unwanted noise and poor sound quality. The Precision Port™ system overcomes these problems and as a result can actually produce a gain of up to 3 dB in output!
Now you can experience good looks, low distortion, and superior overall sound quality thanks to the Precision Port™ system. Convenient front screw holes make this tube easier to install than others on the market. Create a port up to 17" long, then glue with ABS glue found at any hardware store. Installation instructions included. Also available in 2", 4", and 6" diameters. Proudly made in the USA!
To calculate the proper port length for your cabinet and tuning frequency, use Precision Sound Products' Port Length Calculator.
Dimensions: • 6-1/4" outside flare outer diameter • 5-1/4" cutout • 5-3/16" inside flare outer diameter.
BrandPrecision Sound
ModelPSP3-BKHT
Part Number268-350
UPC844632046780
Weight1.28
MONSTER DEAL
OF THE WEEK
$14.98 EACH
SAVE 25%
Dayton Audio Boost Mini Portable Bluetooth Speaker Black
