  • Small Portable 60W Bluetooth Ammo Box Speaker Kit Components without Batteries
Part #300-7308
Part #300-7308
Use this kit to build a quality-sounding Bluetooth portable speaker using a military 30 caliber style ammo box.
  • Fits in most 30 caliber style ammo boxes for convenience
  • Easy to build plug in wiring
  • KAB-230v4 Dayton Audio 2 x 30W Bluetooth amp board for high quality wireless sound
  • Dayton Audio PC83-8 3" poly cone speakers for smooth response and true full-range sound
  • Downloadable build instructions for guidance
Your Price: $109.98
MSRP: $142.99
Save $33.01 (23%)
Quickly build a portable Bluetooth speaker with the Conceal Carry speaker kit. All the components conveniently fit into a 30 caliber style ammo box. You may have one of these metal ammo boxes lying around the house or plastic versions are available at most hardware stores. All you have to do is drill two 3" holes and cut out a 3-2/3" x 2-3/4" hole. All the wires plug directly into the boards without any soldering. Attach the speaker wires to the + and - on the speakers with 0.205" and 0.110" quick disconnects (sold separately) or solder the wires to each terminal. Screw down the speakers with the included screws and attach the speaker wires and you're ready to impress friends with a great sounding, 60W portable Bluetooth speaker. The on board Bluetooth antenna delivers up to 50 ft. of range. If you're mounting the board in a metal enclosure connect an external antenna (sold separately) to the antenna jack on the board. Batteries not included. Add a little sound damping material (sold separately) to make it sound even better.
Note: Crossover components may be substituted with parts of equal or higher quality depending on available inventory.
Part Number300-7308
UPC848864065199
Weight4.54
Cabinet OptionsUnfinished/Unassembled
ConfigurationFull-range
Speaker TypePortable Bluetooth
Woofer Diameter3"
