  • Lishen 18650 2600mAh Li-Ion Flat Top Battery 3-Pack
Lishen
Part #142-103
Lishen
Part #142-103
This economical 3-pack of 18650 Li-Ion batteries combined together will run many low power amp boards and other 12 VDC projects. They work great by themselves in flashlights and other 3.7 VDC devices.
  • Economical 3-pack saves money
  • 2600mAh for long lasting power
  • Long standby time between charges
  • Includes protective storage case
Your Price: $13.98
MSRP: $21.99
Save $8.01 (36%)
Quantity:Qty: 1-3 $13.98/ea
Quantity:Qty: 4+$12.98/ea
377In Stock
18650 batteries fit many different applications and continue to be a fast growing size of Li-Ion battery. Dayton Audio's KAB-BE battery extension board uses three 18650 batteries to power the KAB Bluetooth amp boards for long lasting music. Many LED flashlights use 18650 batteries for a brighter, long lasting beam that can be recharged over-and-over.
Li-Ion batteries work better than other types of rechargeable batteries, because they have a longer standby time. Flashlights sit for months before they're used, in some cases, and when you go to use it, after a couple of months off the charger, the batteries are dead. Li-Ion batteries keep 90% of their charge for six months and are also lighter than other rechargeable batteries that have the same current rating and voltage. The next time you need to buy a flashlight or build a new project make sure long lasting 18650 Li-Ion batteries are its power source.
Specifications: • Voltage: 3.7 VDC • Current rating: 2600mAh • Dimensions: 2.56" L x 0.72" Dia. (65 x 18.25 mm).
BrandLishen
Part Number142-103
UPC848864032948
Weight0.35
Size18650
TechnologyLi-Ion
Voltage3.7V
