  • Polk Audio Monitor XT20 High-Resolution Bookshelf Speaker Pair
Polk Audio
Part #243-614
Polk Audio
Part #243-614
This exceptional speaker delivers lifelike, high-resolution sound that immerses you in a captivating audio experience. With effortless bass reproduction, the Monitor XT20 enriches your audio encounters by adding depth and impact.
  • 6.5" bi-laminate paper woofer delivering clean midrange and punchy bass
  • 1" Terylene dome tweeter providing clear, high-resolution audio up to 40kHz
  • Hi-Res Audio certified for detailed and accurate sound reproduction
  • Dolby Atmos and DTS:X compatible for immersive multidimensional audio experiences
  • Low-resonance, critically braced MDF cabinets minimizing unwanted vibrations for pure sound
  • Nickel-plated binding posts ensuring a direct, lossless connection to your audio system
  • Compact design with removable, precision-fit grilles for versatile placement and aesthetic appeal
Your Price: $199.00
MSRP: $249.00
Save $50.00 (20%)
High-Resolution Sound and Effortless Bass
Elevate your music, movies, TV shows, and gaming experiences to new heights with the extraordinary Monitor XT20. Immerse yourself in dynamic, high-resolution sound that effortlessly delivers powerful bass. With Hi-Res Audio Certification, compatibility with Dolby Atmos and DTS:X, and an affordable, compact design that can fit seamlessly into any space, the MXT20 perfectly embodies Polk's commitment to delivering exceptional sound quality for everyone. Indulge in the audio excellence you deserve, regardless of your budget or room constraints.
Powerful Room-Filling Sound
Hi-Res Audio Certified Performance
Experience an unparalleled audio journey with the Monitor XT20. Equipped with Terylene dome tweeters, this remarkable speaker set transcends the limits of human hearing, delivering playback beyond the 40kHz range. Immerse yourself in an ethereal and pristine high-end energy, as well as a spaciousness that not only captivates your ears but also resonates throughout your being. The MXT20 is the perfect companion for indulging in high-resolution movies, gaming, or immersing yourself in the latest hi-res streaming services such as Apple Music, Tidal, Amazon Music HD, and Qobuz. Elevate your audio experience to a whole new level of richness and depth.
Surprisingly Effortless Bass
Polk has always been renowned for delivering speakers that generate astonishingly powerful bass despite their compact size, and the MXT20 continues this tradition flawlessly. Boasting robust 5.25" high-efficiency woofers that are dynamically balanced, this exceptional speaker set produces a clean and expansive mid-range, along with a punchy and highly responsive bass. With minimal distortion, voices and instruments are rendered with utmost clarity, while movie soundtracks and music are enriched with impactful depth. Prepare to be captivated by every nuance and feel the full force of your favorite content as the MXT20 breathes life into your audio experience.
Dolby Atmos Certified & DTS:X Compatible
The Monitor XT20 effortlessly integrates with the latest Dolby Atmos and DTS:X surround sound enabled AV receivers, as well as 4- and 8-ohm amplifiers, ensuring compatibility without the need for specialized equipment. You can enjoy exceptional sound quality and immersive audio experiences without any hassle or additional investments. The Monitor XT20 is designed to deliver great sound effortlessly, allowing you to fully appreciate its remarkable capabilities with your existing setup.
Built for Pure Listening
Immerse yourself in the pure pleasure of sound with the Monitor XT series. These models are meticulously designed to prioritize the enjoyment of pristine audio. The nickel-plated binding posts ensure a direct and lossless connection, preserving the integrity of the audio signal. Critically braced MDF cabinets effectively isolate the sound produced by the woofer and tweeter, preventing unwanted resonances from detracting from the clarity. Additionally, the precision-fit grilles, which can be easily removed, minimize any interference that could compromise the sonic experience. With Monitor XT, every detail is carefully considered to deliver an unparalleled audio journey of uncompromising quality.
  • Tweeter: 1" Terylene dome
  • Woofer: 6.5” bi-laminate paper
  • Crossover Frequency: 3200Hz
  • Recommended Amplification (wpc): 30—200W
  • Impedance: Compatible with 4- and 8-ohm outputs
  • Overall Frequency Response: 38Hz—40kHz
  • Sensitivity: 87dB
  • Inputs: 5-way nickel-plated binding posts
  • Dimensions (W x H x D): 190.5mmx330mmx279.3mm 7.5"x13"x10.99"
  • Weight: 12Ibs/5.44kg
BrandPolk Audio
ModelMXT20
Part Number243-614
UPC747192133412
Unit of MeasurePairs
Weight29.2
ColorBlack
