  • Polk Audio Monitor XT15 High-Resolution Compact Bookshelf Speaker Pair
1 Question, 1 Answer or
Polk Audio
Part #243-615
Polk Audio
Part #243-615
Experience a compact and budget-friendly audio solution that exceeds expectations—the Monitor XT15. This exceptional speaker set maximizes your enjoyment of music, gaming, and movies by delivering energetic, high-resolution sound with seamless and powerful bass. Whether you use the MXT15 as front left and right channels or as side or surround speakers, it adapts effortlessly to enhance your audio experience in any configuration. Its wall-mountable design offers flexibility in placement, allowing you to optimize your setup according to your preferences and space constraints. With the Monitor XT15, versatility and audio excellence come together in a compact and affordable package.
  • 5.25" dynamically balanced woofer delivering clean midrange and punchy bass
  • 1" Terylene dome tweeter providing clear, high-resolution audio up to 40kHz
  • Hi-Res Audio certified for detailed and accurate sound reproduction
  • Dolby Atmos and DTS:X compatible for immersive multidimensional audio experiences
  • Low-resonance, critically braced MDF cabinets minimizing unwanted vibrations for pure sound
  • Nickel-plated binding posts ensuring a direct, lossless connection to your audio system
  • Compact design with keyhole slots for versatile placement and aesthetic appeal
Your Price: $119.00
MSRP: $149.00
Save $30.00 (20%)
Estimated back in stock 5/16/2025
Alert Me When Available
High-Resolution Sound and Effortless Bass
Elevate your music, movies, TV shows, and gaming experiences to new heights with the extraordinary Monitor XT15. Immerse yourself in dynamic, high-resolution sound that effortlessly delivers powerful bass. With Hi-Res Audio Certification, compatibility with Dolby Atmos and DTS:X, and an affordable, compact design that can fit seamlessly into any space, the MXT15 perfectly embodies Polk's commitment to delivering exceptional sound quality for everyone. Indulge in the audio excellence you deserve, regardless of your budget or room constraints.
Powerful Room-Filling Sound
Hi-Res Audio Certified Performance
Experience an unparalleled audio journey with the Monitor XT15. Equipped with Terylene dome tweeters, this remarkable speaker set transcends the limits of human hearing, delivering playback beyond the 40kHz range. Immerse yourself in an ethereal and pristine high-end energy, as well as a spaciousness that not only captivates your ears but also resonates throughout your being. The MXT15 is the perfect companion for indulging in high-resolution movies, gaming, or immersing yourself in the latest hi-res streaming services such as Apple Music, Tidal, Amazon Music HD, and Qobuz. Elevate your audio experience to a whole new level of richness and depth.
Surprisingly Effortless Bass
Polk has always been renowned for delivering speakers that generate astonishingly powerful bass despite their compact size, and the MXT15 continues this tradition flawlessly. Boasting robust 5.25" high-efficiency woofers that are dynamically balanced, this exceptional speaker set produces a clean and expansive mid-range, along with a punchy and highly responsive bass. With minimal distortion, voices and instruments are rendered with utmost clarity, while movie soundtracks and music are enriched with impactful depth. Prepare to be captivated by every nuance and feel the full force of your favorite content as the MXT15 breathes life into your audio experience.
Dolby Atmos Certified & DTS:X Compatible
The Monitor XT15 effortlessly integrates with the latest Dolby Atmos and DTS:X surround sound enabled AV receivers, as well as 4- and 8-ohm amplifiers, ensuring compatibility without the need for specialized equipment. You can enjoy exceptional sound quality and immersive audio experiences without any hassle or additional investments. The Monitor XT15 is designed to deliver great sound effortlessly, allowing you to fully appreciate its remarkable capabilities with your existing setup.
Built for Pure Listening
Immerse yourself in the pure pleasure of sound with the Monitor XT series. These models are meticulously designed to prioritize the enjoyment of pristine audio. The nickel-plated binding posts ensure a direct and lossless connection, preserving the integrity of the audio signal. Critically braced MDF cabinets effectively isolate the sound produced by the woofer and tweeter, preventing unwanted resonances from detracting from the clarity. Additionally, the precision-fit grilles, which can be easily removed, minimize any interference that could compromise the sonic experience. With Monitor XT, every detail is carefully considered to deliver an unparalleled audio journey of uncompromising quality.
  • Tweeter: 1" Terylene dome
  • Woofer: 5.25” bi-laminate paper
  • Crossover Frequency: 2200Hz
  • Recommended Amplification (wpc): 30—150W
  • Impedance: Compatible with 4- and 8-ohm outputs
  • OverallFrequency Response: 48Hz—40kHz
  • Sensitivity: 86dB
  • Inputs: 5-way nickel-plated binding posts
  • Dimensions (WxHxD): 165.1mmx269.2mmx182.4mm6.5"x10.6"x7.18"
  • Weight 9Ibs/4.08kg
BrandPolk Audio
ModelMXT15
Part Number243-615
UPC747192133375
Unit of MeasurePairs
Weight22.75
