We use cookies to provide the best possible customer experience across this site, through third party ads and analysis of web data. By continuing you agree to our use of cookies and our overall privacy policy.
  • CONTACT US
  • SIGN IN
    SIGN IN
  • CART  (0)
    0 item(s) in your cart:
    Your cart is empty
CHECKOUT
CHECKOUT
Secure Shopping
SHOP
  • New Products
  • Shop by Brand
  • Home A/V
  • Speaker Components
  • Pro Audio
  • Car Audio
  • Electronic Parts
  • Connectors & Adapters
  • Tools & Supplies
  • Battery & Power
  • Wire & Cables
  • Novelty
DEALS
  • On Sale
  • Outlet Center
  • Special Buys
  • Open Box & Refurbished
  • Gift Certificates
PROFESSIONAL
  • Commercial Accounts
  • OEM/ODM Services
  • Business Forms
  • Education
  • Installer/Integrator Referral Network
  • Installer/Integrator Referral Sign-up
GET HELP
  • FAQs
  • Tech Support
  • Woofer Replacement Tool
  • Track My Order
  • Contact Us
LEARN
  • Resource Center
  • Customer Project Gallery
  • TechTalk Forum
  • Polk Audio Atrium 4 Outdoor Loudspeaker with 4-1/2" Woofer Pair
Read 1 Review | 1 Question, 1 Answer or
Polk Audio
Part #243-625
Polk Audio
Part #243-625
Model: Atrium 4
4.5 in.5 in.5.25 in.8 in.10 in. Subwoofer
Experience the power of big, high-quality sound that fills large spaces with lifelike audio for all your outdoor entertainment needs. Designed to be a workhorse, this exceptional speaker is capable of delivering remarkable sound that will captivate and immerse you in your outdoor activities. Built with durability in mind, it is constructed to withstand the elements, ensuring that you can enjoy exceptional performance for years to come.
  • Dynamic Balance® drivers for accurate, high-fidelity sound outdoors
  • PowerPort® bass venting for deep, distortion-free low-frequency response
  • Weather-resistant design meets military-grade durability standards
  • Wide sound dispersion for balanced coverage across outdoor spaces
  • Speed-Lock™ mounting system for fast, secure, and adjustable installation
  • Multiple size and configuration options to suit any outdoor setup
  • Rustproof aluminum grilles and stainless steel and brass hardware for to prevent rust
See all items in Outdoor Speakers
Your Price: $199.00
We'll send you an email when Polk Audio Atrium 4 Outdoor Loudspeaker with 4-1/2" Woofer Pair is back in stock or available for preorder.
Share
Share
Frequently Bought Together
$199.00
$11.98
Total Price: $210.98
This Product:Polk Audio Atrium 4 Outdoor Loudspeaker with 4-1/2" Woofer Pair$199.00
Waterproof UV Direct Burial Silicone Filled Wire Nuts for Landscape/Outdoor Speaker Connection 20-Pack$11.98
2 ItemsTotal Price: $210.98
Polk Audio Atrium 4 Outdoor Speaker Pair
Small Size, Massive Sound
With its robust design, the Atrium5, like all our outdoor models, is crafted to endure the elements, ensuring exceptional performance that will last for years. Now, you can experience the same outstanding indoor sound you love, but with the convenience of an outdoor loudspeaker that can be placed anywhere around your home. Whether you desire to create an outdoor entertainment area, enhance your patio ambiance, or add audio to your garden, the Atrium5 delivers unparalleled sound quality, allowing you to enjoy your favorite tunes and audio content wherever you desire.
Flexible and Adaptable
Patented Dynamic Balance®
Whether you're relaxing in your favorite chair, hosting a lively BBQ, or enjoying quality time with your family outdoors, the Atrium Series outdoor speakers guarantee that you won't miss a single word of your favorite tunes. Featuring Patented Dynamic Balance® and Klippel Optimization Technologies, they are meticulously designed to ensure optimal material performance. These technologies eliminate driver and tweeter "artifacts," resulting in more realistic sound reproduction across a wide range of volume levels.
Polk All-Weather Certified
Designed to endure the elements, the Atrium Series speakers are built to last and deliver rich, lifelike, space-filling sound regardless of the weather conditions. These speakers exceed baseline industrial and military specifications for environmental endurance, such as ASTM D5894-UV Salt Fog, Mil Standard 810 Immersion, and Mil-Std 883 Method 1009.8 for salt and corrosion. This means they are rigorously tested and proven to withstand challenging outdoor environments.
Speed-Lock Mounting System
Revitalizing your patio or backyard becomes effortless with the Atrium Series speakers, thanks to their easy and secure one-handed installations, even in challenging locations. The innovative Speed-Lock Mounting System guarantees a simple and safe one-handed installation process, along with a no-slip setting for the speaker angle. This streamlined mounting procedure minimizes the number of parts required and accelerates the setup time.
  • Driver Complement: 4-1/2" (114mm) mineral filled Dynamic Balance® polymer cone, rubber surround, 3/4" (19mm) anodized aluminum dome tweeter w/ rubber surround and neodymium motor structure
  • Frequency Response: 75Hz - 25kHz
  • Recommended Power: 10-80W
  • Impedance: Compatible w/ 8 Ohm outputs
  • Efficiency (dB 1w/1m): 89dB
  • Environmental Standards: ASTM D5894-UV Salt Fog, Mil Standard 810 Immersion, Mil-Std 883 Method 1009.8 for salt and corrosion & Polk Audio Certification
  • Cabinet Material: Mineral filled polypropylene
  • Grille & Bracket Material: Powder Coated Aluminum
  • Hardware: Brass or stainless steel
  • Terminals: Gold played 5-way binding posts
  • Mounting Options: 180° Speed-Lock™ mounting
  • Dimensions (w/ bracket and knobs): 8-5/8" H x 5-11/16" W x 6-11/16" D (21.9cm H x 14.4cm W x 17cm D)
  • Weight: 3.6 lbs. / 1.63 kg (each)
BrandPolk Audio
ModelAtrium 4
Part Number243-625
UPC747192118792
Unit of MeasurePairs
Weight9.05
ColorBlack
Woofer Diameter4.5"
  • Polk Audio Atrium Loudspeaker User's Manual
  • Polk Audio Atrium 4 Information Sheet
  • Polk Audio Manufacturer Warranty
Our Company
  • About Parts Express
  • Careers
  • Retail Store – Springboro, OH
  • Press Releases
  • Brand Ambassador Program
  • Get Email Offers
  • Catalog & Sales Flyer
  • Speaker Design Competition
Orders & Returns
  • Track My Order
  • Free Shipping Offer
  • 60 Day No-Hassle Returns
  • Promotional Exclusions
Professional
  • OEM/ODM Services
  • Business Forms
  • Education
  • Installer/Integrator Referral Sign-Up
Community
  • TechTalk Forums
Get Connected
  • YouTube
  • Twitter
  • Instagram
  • Facebook
  • Pinterest
Customer Service
Live Chat
Contact Us
  • FAQs
  • Tech Support
  • Resource Center
  • Accessibility Statement
  • Customer Feedback
© 1996-2025 Parts Express All Rights Reserved
725 Pleasant Valley Dr.
Springboro, OH 45066 USA
  • Terms of Use
  • Privacy Policy
  • International Orders
  • Contact
  • Terms of Use
  • Privacy Policy
