  • Peerless SLS-85S25CP04-04 3-1/2" Paper Cone Woofer 4 Ohm
Peerless by Tymphany
Part #264-1600
Model: SLS-85S25CP04-04
With a low Fs and 4.5 mm of excursion, the 3-1/2" Peerless SLS-85S25CP04-04 will produce powerful bass response in small speaker designs. In addition, an aluminum shorting ring and smooth response up to 5,000 Hz ensures low distortion and accuracy throughout the midrange frequencies.
  • This small driver is capable of delivering a big sound
  • Low Fs and high Xmax makes this small driver capable of big sound
  • Damped paper cone with rubber surround provides natural response
  • Dual magnet design concentrates the magnetic field on the voice coil gap
Your Price: $17.38
MSRP: $29.99
Save $12.61 (42%)
Quantity:Qty: 1000+$17.38/ea
Out of Stock
Ships in 90-120 days. Minimum order quantity 1,000 pcs.
Alert Me When Available
The SLS-85S25CP04-04 3-1/2" paper cone woofer from Peerless is an extremely impressive driver for its size. With high excursion capabilities and low resonant frequency, you can expect a considerable amount of low end from compact designs. However, beyond that this driver excels throughout the midrange frequencies thanks to an aluminum shorting ring, optimized magnet, and damped paper cone making this driver ideal for use in ultra-compact 2-way designs and portable speaker systems.
BrandPeerless by Tymphany
ModelSLS-85S25CP04-04
Part Number264-1600
UPC848864044859
Weight2
Nominal Diameter3-1/2"
Bolt Circle Diameter3.79
Power Handling (RMS)30 Watts
Power Handling (MAX)60 Watts
Frequency Response70 to 6,000Hz
Sensitivity85.98dB 2.83V/1m
Voice Coil Diameter1"
Resonant Frequency (Fs)72Hz
DC Resistance (Re)3.18Ω
Voice Coil Inductance (Le)0.16mH
Mechanical Q (Qms)5.38
Electromagnetic Q (Qes)0.37
Total Q (Qts)0.35
Compliance Equivalent Volume (Vas)0.049ft³
Mechanical Compliance of Suspension (Cms)1.023mm/N
BL Product (BL)4.31T·m
Diaphragm Mass Inc. Airload (Mms)4.7g
Maximum Linear Excursion (Xmax)4.5mm
Surface Area of Cone (Sd)30.8cm²
Cone MaterialTreated Paper
Overall Outside Diameter4.13, Across flats: 3.58"
Baffle Cutout Diameter2.96"
Depth3"
# Mounting Holes6
Sealed Volume0.03ft³
Sealed F3170.9Hz
Vented Volume0.05ft³
Vented F371.6Hz
MONSTER DEAL
OF THE WEEK
$24.98 EACH
SAVE $5
Lepai LP-2020BT Bluetooth Hi-Fi Audio Mini Class D Stereo Amplifier FM Media with Power Supply
