Dayton Audio ND91-4 3-1/2" Aluminum Cone Full-Range Neo Driver 4 Ohm
Dayton Audio
Part #290-224
Dayton Audio
Part #290-224
The low distortion and high excursion capabilities of the Dayton Audio ND91-4 3-1/2" full-range driver make it an ideal candidate for miniature point-source monitors, surround speakers, and line arrays. When teamed up with the matching ND series passive radiators this driver can produce incredible full sound from compact enclosures.
- Low distortion, full-range 65 Hz to 17 kHz performance
- Rubber-edged black anodized aluminum alloy cone
- Large excursion capability—4.6 mm Xmax, 25 mm peak
- Self-shielded Neo-Balanced motor structure with copper alloy shorting ring
- 1" 4-layer underhung voice coil with polyimide former
- 30 watts RMS power handling
- Great for line arrays and micro monitors
