  • Peerless by Tymphany NE265W-08 10" Paper Cone NE Woofer 8 Ohm
NEW Peerless by Tymphany NE265W-08 10" Paper Cone NE Woofer 8 Ohm
Part #264-1518
Model: NE265W-08
The Peerless NE Series full-range drivers feature an innovative sculpted, open cast aluminum basket design that minimizes internal acoustic reflections and acts as the neodymium motor's heatsink.
  • Cast aluminum frame promotes motor cooling
  • Sculpted design improves airflow and reduces reflections
  • High-strength compact neodymium magnet system
  • Proprietary coated natural wood fiber cone with half-roll rubber surround
  • Long-throw 2" voice coil on titanium former
  • Copper pole piece cap for extended HF response
  • 8 ohm nominal impedance
NEW $204.82
MSRP: $307.99
Save $103.17 (33%)
Quantity:Qty: 1-3 $204.82/ea
Quantity:Qty: 4+$184.34/ea
Estimated back in stock 5/2/2025
Alert Me When Available
The Peerless NE Series full-range drivers feature an innovative sculpted, open cast aluminum basket design that minimizes internal acoustic reflections and acts as the neodymium motor's heatsink. An additional heatsink provides extra thermal dissipation. The cone is constructed of a coated natural wood fiber, with a butyl rubber surround designed by finite element analysis for linearity of performance. FEA techniques also contribute to the motor's copper cap, which reduces inductance.
BrandPeerless by Tymphany
ModelNE265W-08
Part Number264-1518
UPC848864045870
Weight5.1
Nominal Diameter10"
Power Handling (RMS)125 Watts
Power Handling (MAX)250 Watts
Frequency Response20 to 2,000Hz
Sensitivity85.08dB 2.83V/1m
Resonant Frequency (Fs)22.97Hz
DC Resistance (Re)6.24Ω
Voice Coil Inductance (Le)0.53mH
Mechanical Q (Qms)10.33
Electromagnetic Q (Qes)0.31
Total Q (Qts)0.3
Compliance Equivalent Volume (Vas)3.43ft³
Mechanical Compliance of Suspension (Cms)0.65mm/N
BL Product (BL)14.7T·m
Diaphragm Mass Inc. Airload (Mms)74.1g
Maximum Linear Excursion (Xmax)9.4mm
Surface Area of Cone (Sd)326.9cm²
Sealed Volume0.6ft³
Sealed F360.7Hz
Vented Volume1.2ft³
Vented F337.4Hz
