  • Peerless by Tymphany NE180W-08 6-1/2" Fiber Cone Woofer Speaker
Part #264-1134
Tymphany's NE180W-08 6-1/2" speaker is an advanced, well-engineered woofer and midbass driver designed for accurate audio reproduction.
  • Cast aluminum frame promotes motor cooling
  • Sculpted design improves airflow and reduces reflections
  • High-strength compact neodymium magnet system
  • Proprietary coated natural wood fiber cone with half-roll rubber surround
  • Long-throw 1-1/2" voice coil on titanium former
  • Copper pole piece cap for extended HF response
  • 8 ohm nominal impedance
Your Price: $87.70
MSRP: $161.99
Save $74.29 (46%)
Quantity:Qty: 1-3 $87.70/ea
Quantity:Qty: 4+$83.32/ea
Out of Stock
Advertised price subject to change due to tariff uncertainty
Alert Me When Available
The Tymphany NE180W-08 6-1/2" Neodymium Woofer is characterized by the NE Series' cast aluminum basket; an innovative sculpted, open design that minimizes internal acoustic reflections and assists the neodymium motor's thermal management.
A coated natural wood fiber cone with a butyl rubber surround is FEA optimized for linearity of performance. Finite element analysis techniques also contribute to inclusion of the motor's copper cap, which reduces inductance and extends the speaker's upper frequency performance.
BrandPeerless by Tymphany
ModelNE180W-08
Part Number264-1134
UPC844632092619
Weight1.95
Nominal Diameter6-1/2"
Power Handling (RMS)80 Watts
Power Handling (MAX)160 Watts
Frequency Response40 to 4,000Hz
Sensitivity87.4dB 2.83V/1m
Voice Coil Diameter1.5"
Resonant Frequency (Fs)42Hz
DC Resistance (Re)6.2Ω
Voice Coil Inductance (Le)0.12mH
Mechanical Q (Qms)7.4
Electromagnetic Q (Qes)0.41
Total Q (Qts)0.39
Compliance Equivalent Volume (Vas)0.8ft³
Mechanical Compliance of Suspension (Cms)0.86mm/N
BL Product (BL)8.17T·m
Diaphragm Mass Inc. Airload (Mms)16.39g
Surface Area of Cone (Sd)136.9cm²
Cone MaterialWood Fiber
Voice Coil FormerTitanium
Magnet MaterialNeodymium
Overall Outside Diameter7.09"
Baffle Cutout Diameter6.18"
Depth3.65"
# Mounting Holes5
Sealed Volume0.3ft³
Sealed F385.2Hz
Vented Volume0.6ft³
Vented F346.5Hz
