  • Peerless DA25TX00-08 1" Corundum Dome Tweeter
Peerless by Tymphany
Part #264-1676
Model: DA25TX00-08
Built for industry leading performance, the Peerless DA25TX-08 1" corundum dome tweeter delivers amazing performance for an unbeatable value. With a low Fs and high excursion capability, this tweeter can handle extremely low crossover frequencies while producing minimal distortion. In addition, the on and off-axis response is so smooth this tweeter will be right at home in any reference quality system.
  • Remarkably flat response from 1,000 thru 20,000 Hz (± 1.5 dB)
  • Large copper cap lowers inductance and minimizes distortion
  • Underhung copper voice coil on a vented aluminum former with ample excursion capability
  • Deep rear chamber with integrated heatsink for low Fs and high power handling
  • Corundum dome is extremely rigid with excellent damping
  • Huge motor assembly provides excellent control and high efficiency
Your Price: $53.36
MSRP: $74.99
Save $21.63 (29%)
Quantity:Qty: 1-3 $53.36/ea
Quantity:Qty: 4+$49.90/ea
Out of Stock
Advertised price subject to change due to tariff uncertainty
Alert Me When Available
Peerless designed the DA25TX00-08 1" corundum dome tweeters for both hi-fi and professional applications. With their unique material and design enhancements, these tweeters are built for industry-leading performance and reliability. Corundum, one of natured hardest substances (9 out of 10 on the MOHS hardness scale), is extremely rigid with excellent damping which pushes any dome resonance well outside of the audible range keeping frequency response flat to 20,000 Hz and beyond. The DA25TX00-08 incorporates a unique rear chamber that lowers the resonant frequency and serves as a heatsink for improved power handling and negligible power compression. The massive FEA optimized underhung motor assembly provides incredible control for impressive dynamics, and includes a thick copper cap on the pole piece for lower inductance with minimal distortion. In addition, the optional metal grill (held in place magnetically) protects the fragile dome from foreign objects and curious fingers. Capable of handling crossover frequencies as low as 1,200 Hz, the DA25TX00-08 will present outstanding performance in almost any 2 or 3-way speaker designs.
BrandPeerless by Tymphany
ModelDA25TX00-08
Part Number264-1676
UPC848864051062
Weight3
Cone / Dome Diameter1"
Cutout Diameter3.5
Tweeter TypeCorundum Dome
Power Handling (RMS)100 Watts
Frequency Response1,000 to 40,000Hz
Sensitivity88.7dB 2.83V/1m
Resonant Frequency (Fs)633Hz
DC Resistance (Re)6.89Ω
Voice Coil Inductance (Le)0.01mH
Mechanical Q (Qms)1.98
Electromagnetic Q (Qes)0.85
Total Q (Qts)0.6
Overall Outside Diameter4.8125"
Depth2.75"
