  • Peerless by Tymphany 830991 5-1/4" GFC Cone HDS Woofer
Part #264-1074
Model: HDS-P830991
The Peerless High Definition Sound (HDS) Series offers high-quality solutions for multi-way speaker systems employing vented box alignments.
  • Truncated cast aluminum frame
  • Glass-Fibre Composite (GFC) cone with half-roll rubber surround
  • Long-throw voice coil
  • Shorting rings for reduced distortion
  • Under-spider and voice coil ventilation
Your Price: $35.53
MSRP: $62.99
Save $27.46 (44%)
Quantity:Qty: 504+$35.53/ea
Out of Stock
Ships in 90-120 days, minimum order quantity 500 pcs.
Alert Me When Available
The Peerless High Definition Sound (HDS) Series offers high-quality solutions for multi-way speaker systems employing vented box alignments. A powerful ferrite magnet system is coupled to a finite element analysis-designed suspension system, containing a linear spider design and rubber surround. The motor incorporates an aluminum shorting ring that reduces coil inductance, extending frequency response performance and reducing second harmonic distortion. A cast aluminum basket provides high structural rigidity, heat-sinking capacity for the motor, and additional ventilation under the spider that in combination with a vented cone neck reduces air compression effects. The Glass-Fibre Composite (GFC) cone offers a unique acoustic and visual experience.
BrandPeerless by Tymphany
ModelHDS-P830991
Part Number264-1074
UPC844632083983
Weight2.45
Nominal Diameter5-1/4"
Power Handling (RMS)30 Watts
Power Handling (MAX)60 Watts
Frequency Response20 to 5,000Hz
Sensitivity87dB 2.83V/1m
Voice Coil Diameter1"
Resonant Frequency (Fs)66Hz
DC Resistance (Re)
Voice Coil Inductance (Le)0.33mH
Mechanical Q (Qms)2.96
Electromagnetic Q (Qes)0.58
Total Q (Qts)0.49
Compliance Equivalent Volume (Vas)0.24ft³
Mechanical Compliance of Suspension (Cms)0.6mm/N
BL Product (BL)6.42T·m
Diaphragm Mass Inc. Airload (Mms)9.7g
Maximum Linear Excursion (Xmax)4.55mm
Surface Area of Cone (Sd)89.9cm²
Cone MaterialFiberglass
Overall Outside Diameter6"
Baffle Cutout Diameter4.75"
Depth2.77"
# Mounting Holes6
Sealed Volume0.2ft³
Sealed F3106.6Hz
Vented Volume0.4ft³
Vented F356.1Hz
MONSTER DEAL
OF THE WEEK
$98.98 EACH
SAVE 40%
Dayton Audio DTA-PRO 100W Class D Bluetooth Amplifier with USB DAC IR Remote and Sub Output
