Peerless by Tymphany PLS Series 65F25AL02 2-1/2" Aluminum Full-Range Speaker
- Aluminum cone and voice coil cap for durability and use in high moisture environments
- Large-roll rubber surround for extended mechanical excursion
- Full-range response from 100 to 15,000 Hz
- Truncated steel frame for close center-to-center placement in column line array speakers
- Low inductance, low distortion motor with copper cap and maximum voice coil venting
Out of Stock
We'll send you an email when Peerless by Tymphany PLS Series 65F25AL02 2-1/2" Aluminum Full-Range Speaker is back in stock or available for preorder.
