  • Dayton Audio PC68-8 2-1/2" Full-Range Poly Cone Driver
Dayton Audio
Part #295-152
Dayton Audio
Part #295-152
Model: PC68-8
Dayton Audio's PC68-8 2-1/2" full-range driver will deliver smooth and natural response from extremely compact designs. When used in line arrays, portable speakers, sound bars, or as a dedicated midrange in 3-way designs this driver will prove to be an excellent value.
  • Poly damped woven glass fiber cone controls cone break-up and provides a smooth roll-off
  • High energy ferrite magnet increases BL for higher efficiency and increased output
  • Rubber surround improves cone linearity and transients
  • Smooth response with true full-range reproduction for simple speaker designs
Your Price: $10.29
MSRP: $13.99
Save $3.70 (26%)
Quantity:Qty: 1-3 $10.29/ea
Quantity:Qty: 4+$9.26/ea
151In Stock
The Dayton Audio PC68-8 2-1/2" full-range driver features a poly damped woven glass fiber cone, rubber surround, and high energy motor. Offering great full-range performance, controlled off-axis response, and high efficiency, this driver will provide impressive output for its size. Perfect for use in line arrays, sound bars, portable speakers, or even car audio the Dayton Audio PC68-8 driver will deliver high fidelity and low distortion from compact applications for an amazing value.
ModelPC68-8
Part Number295-152
UPC848791003998
Weight0.65
Nominal Diameter2-1/2"
Bolt Circle Diameter2.89
Power Handling (RMS)20 Watts
Power Handling (MAX)40 Watts
Frequency Response110 to 17,000Hz
Sensitivity85.6dB 2.83V/1m
Voice Coil Diameter0.75"
Resonant Frequency (Fs)109Hz
DC Resistance (Re)6.9Ω
Voice Coil Inductance (Le)0.47mH
Mechanical Q (Qms)2.27
Electromagnetic Q (Qes)0.88
Total Q (Qts)0.64
Compliance Equivalent Volume (Vas)0.05ft³
Mechanical Compliance of Suspension (Cms)1.05mm/N
BL Product (BL)3.3T·m
Diaphragm Mass Inc. Airload (Mms)2g
Surface Area of Cone (Sd)21.2cm²
Cone MaterialPoly Composite
Voice Coil Wire MaterialCCA
Voice Coil FormerAluminum
Overall Outside Diameter2.68"
Baffle Cutout Diameter2.52"
Depth1.46"
Sealed Volume0.06ft³
Sealed F3145Hz
Vented Volume0.1ft³
Vented F377Hz
MONSTER DEAL
OF THE WEEK
$19.98 EACH
SAVE $10
