  • Hi-Fidelity Passive Dayton Audio Epique 7" Mini Subwoofer Kit
Part #300-7324
Part #300-7324
Occupying only 0.35 cubic feet, this Hi-Fidelity passive mini 7" subwoofer kit will deliver surprisingly powerful output making it a perfect addition to smaller stereo and home theater systems. With the brand new Epique H180HE-44 MMAG ultra-low distortion 7" driver and precision CNC cut compact enclosure, this system can be used as a dedicated subwoofer, or used as a small separate woofer bin in a multi-way design.
  • Extremely compact design will fit almost anywhere
  • Use multiples to help minimize room modes for more even, room-filling low end
  • High excursion, extended range Epique E180HE-44 7" driver provides powerful output capability
  • CNC-cut 3/4" MDF panels for precise fit, easy assembly, and smooth finish
  • Kit includes pre-cut knock down enclosure, subwoofer driver, and mounting screws.
Your Price: $189.98
MSRP: $369.98
Save $180.00 (49%)
Order in the next 2 hr 47 min to ship today. Details
Housed in just a 10” cube, the Hi-Fidelity Epique E180HE-44 7" Passive Mini Subwoofer Kit is the perfect solution for providing high performance bass response without taking up much space. With the Epique high excursion extended range E180HE-44 7" subwoofer driver you can expect incredibly accurate response with ultra-low distortion. Thanks to the small size this subwoofer is ideal for using multiples strategically positioned around rooms to minimize room nodes (null and peaks) for more even bass distribution.
If your endgame is ultimate fidelity in a small package, this is the subwoofer for you. The Epique E180HE-44 will immerse you in clarity and low distortion low frequencies. Perfect for a desktop, 2.1 music system, small studio or even in your car, the Hi-Fidelity Epique 7" mini subwoofer kit is one of the best sounding small subwoofers available anywhere.
Simulated Performance Specifications: • Maximum output: 107 dB • F3: 60 Hz • F10: 34 Hz
Epique H180HE-44 7" Subwoofer Specifications: • Power handling: 200 watts RMS/400 watts max • Le: 1.5 mH • Impedance: 8 ohms (series)• Re: 6.8 ohms • Frequency range: 25 to 3,000 Hz • Fs: 35 Hz • SPL: 85.7 dB 2.83V/1m • Vas 0.57 cu. ft. • Qms: 2.93 • Qes: .54 • Qts: .46 • Xmax: 14.7 mm.
Enclosure Specifications: • Panel thickness: 3/4" • Panel material: Medium Density Fiberboard (MDF) • Finished internal cabinet volume: 0.35 cubic feet • External dimensions: 10" H x 10" W x 10" D • Weight: 23 lbs. • Made in the USA.
Note: Binding posts and cabinet feet are not included.
Part Number300-7324
UPC848864071961
Weight8.6
Cabinet Dimensions (HxWxD)10" H x 10" W x 10" D
Cabinet OptionsUnfinished/Unassembled
ConfigurationSubwoofer
Speaker TypePassive / Unpowered
Woofer Diameter7"
