  • PRV Audio TW700Ti High Power Titanium Bullet Super Tweeter 8 Ohm
PRV Audio
Part #294-2809
PRV Audio
Part #294-2809
Model: TW700Ti
Add detail to any speaker with PRV Audio's TW700Ti titanium bullet super tweeter! With high frequency response up to 20,000 Hz and a sensitivity of 108 dB at 1W/1m, the TW700Ti can keep up with even the most demanding speaker systems. Flat sides allow for close side by side mounting.
  • Titanium ring-radiator diaphragm for accurate and detailed response
  • Kapton® voice coil former ensures high power handling and reliability
  • Front mount design for easy installation, flat sides for side-by-side multiple driver arrays
  • High 108 dB sensitivity and 120 watt RMS power handling
  • Designed for ultra-high frequency use from 3,500-20,000 Hz
Your Price: $37.91
MSRP: $47.39
Save $9.48 (20%)
23In Stock
PRV Audio's TW700Ti super tweeter (also referred to as a bullet tweeter) is designed to add high output, high frequency response to any speaker system. The titanium, ring-radiator diaphragm combines with the durable, yet light weight, Kapton™ voice coil former for sensitivity levels of up to 108 dB from 3,500 to 20,000 Hz. A controlled 50° x 50° coverage pattern reduces reflections and close side by side mounting is facilitated by flat sides.
Not only does this driver look as good as it sounds it is also able to take a huge amount of power due to its 1.5" diameter copper voice coil. Up to 120 watts of power handling are on tap with a 12 dB/octave crossover at 5,000 Hz to keep up with the most demanding professional audio, high output home audio, and high SPL car audio systems. A capacitor is included for protection from damaging frequencies at high power. Mounting hardware included.
Specifications: • Power handling: 120 watts RMS with recommended crossover of 5,000 Hz, 12 dB/octave • Minimum recommended crossover point: 5,000 Hz • VCdia: 1.7" • Impedance: 8 ohms • Frequency response: 3,500-20,000 Hz • SPL: 108 dB 1W/1m • Dimensions (H x W x D): 4" x 4" x 2.55" • Replacement diaphragm available (294-2819).
BrandPRV Audio
ModelTW700Ti
Part Number294-2809
UPC810075520743
Weight3.55
Diaphragm MaterialTitanium
Power Handling (RMS)120 Watts
MONSTER DEAL
OF THE WEEK
$98.98 EACH
SAVE 40%
Dayton Audio DTA-PRO 100W Class D Bluetooth Amplifier with USB DAC IR Remote and Sub Output
