  • PRV Audio 1DF5200H High Pass Crossover Board 5,200/6,800 Hz with Selectable Attenuation
PRV Audio
Part #294-2866
PRV Audio
Part #294-2866
Model: 1DF5200H
Get your professional audio speaker cabinet up and running like new (or build your own custom speaker) with the PRV Audio 1DF5200H 5,200/6,800 Hz high-pass super tweeter crossover.
  • 5,200 or 6,800 Hz high-pass filter with selectable 4 dB attenuation
  • 100 watts RMS, 200 watts program power handling
  • Designed for use with bullet super tweeters
  • Made in Brazil
Your Price: $28.41
MSRP: $35.51
Save $7.10 (20%)
PRV Audio's high-pass 1DF5200H compression driver crossover is designed to be used with passive (unpowered) compression super tweeters. Selectable 5,200 Hz and 6,800 Hz crossover points (with 12 dB/octave filter slopes) allow you to integrate many bullet tweeters with most professional audio midrange and woofer drivers. Selectable 0 dB or 4 dB attenuation provides convenient level matching.
High quality components are used throughout for longevity and great sound, and the crossover point (as well as attenuation) is selected by a convenient on-board jumper. Made in Brazil.
Specifications: • Power handling: 100 watts RMS, 200 watts program power • Crossover points: 5,200 Hz or 6,800 Hz, 12 dB/octave • Attenuation: 0 or 4 dB.
BrandPRV Audio
Model1DF5200H
Part Number294-2866
UPC799928734639
Weight0.395
Crossover TypeHigh Pass
MONSTER DEAL
OF THE WEEK
$98.98 EACH
SAVE 40%
Dayton Audio DTA-PRO 100W Class D Bluetooth Amplifier with USB DAC IR Remote and Sub Output
