  • PRV Audio D3220Ti 2" Titanium Horn Compression Driver 8 Ohm 4-Bolt
PRV Audio
Part #294-2850
PRV Audio
Part #294-2850
Model: D3220Ti
Upgrade your speaker cabinets today using PRV Audio's D3220Ti 2" compression driver. High output and smooth frequency response allows you to use this horn driver in almost any high output audio application: pro, home, or car. Standard 4 bolt pattern.
  • Kapton® former and titanium diaphragm for neutral sound
  • Designed for high frequency use 1,200 to 17,000 Hz
  • High 108 dB sensitivity
  • Four M6 bolt holes for secure horn coupling with included mounting bolts
  • Spring-loaded speaker terminals
Your Price: $79.91
MSRP: $99.89
Save $19.98 (20%)
PRV Audio's D3220Ti 2" pure titanium compression driver offers a surprisingly smooth, neutral sound not normally found in titanium compression drivers at this price point. In fact, the D3220Ti competes with drivers costing up to three times as much! A 2" exit and four bolt pattern makes this the perfect upgrade horn driver for many popular professional audio speaker cabinets.
High output mobile audio enthusiasts choose the PRV Audio D3220Ti for extreme SPL car audio competitions in South America, while DJs use it in high SPL speaker cabinets for entertaining crowds that number in the thousands.
The pure titanium diaphragm is attached to a 3" diameter copper voice coil with Kapton® former for the lowest possible moving mass without sacrificing power handling. This allows for an amazing 108 dB of output with only 1 watt of input power, when measured at one meter, for use in even the loudest of environments! Mounting hardware is included
Specifications: • Power handling: 110 watts RMS with recommended crossover of 1,600 Hz, 12 dB/octave slope • VCdia: 3" • Impedance: 8 ohms • Frequency response: 1,200-17,000 Hz • SPL: 108 dB 1W/1m • Dimensions: 6.5" diameter x 2.75" depth • Net weight: 8.8 lbs. • Mounting: 4 x M6 bolt holes on a 4" diameter (hardware included) • Replacement diaphragm available (please see Related Items).
BrandPRV Audio
ModelD3220Ti
Part Number294-2850
UPC799928733809
Weight10.5
Diaphragm MaterialTitanium
Exit Diameter2"
Mounting Type4-Bolt
Power Handling (RMS)110 Watts
MONSTER DEAL
OF THE WEEK
$98.98 EACH
SAVE 40%
Dayton Audio DTA-PRO 100W Class D Bluetooth Amplifier with USB DAC IR Remote and Sub Output
