PRV Audio D280Ti-B 1" Titanium Horn Compression Driver 8 Ohm 2/3-Bolt
Upgrade your PA speaker cabinets today using PRV Audio's amazing D280Ti compression driver. High output and smooth frequency response allows you to use this horn driver in almost any high output audio application: pro, home, or car. Standard 2/3-bolt mounting pattern.
- 1-inch throat diameter
- Titanium diaphragm for durability and precise sound reproduction
- 80 watts RMS and 160 watts program power for robust performance
- High sensitivity of 109 dB at 2.83V/1m for efficient sound output
- Frequency response range of 1,300 Hz to 20,000 Hz for wide coverage
- Screw-on type connection for easy installation and replacement
- Lightweight design for seamless integration
We'll send you an email when PRV Audio D280Ti-B 1" Titanium Horn Compression Driver 8 Ohm 2/3-Bolt is back in stock or available for preorder.
