  • PRV Audio 8MB700FT-NDY 8" Neodymium Speaker 8 Ohms
1 Question, 9 Answers or
PRV Audio
Part #294-2773
PRV Audio
Part #294-2773
Model: 8MB700FT-NDY
Specially designed for more power handling and less distortion, PRV Audio's 8MB700FT-NDY 8" midrange is an excellent addition to any high output sound system. With 98 dB sensitivity, this driver is capable of generating a lot of output even with moderate input power.
  • Powerful neodymium motor allow minimum weight and high efficiency
  • Composite non-pressed paper cone for reduced break-up and smooth response
  • Large 2-1/2" voice coil allows for the high 350 watt power handling and high BL
  • Extensive venting keeps air moving across the coil for low power compression
Your Price: $159.91
MSRP: $199.89
Save $39.98 (20%)
10In Stock
With high efficiency and power handling, the 8MB700FT-NDY 8" midrange from PRV Audio is capable of incredible overall output while producing very low distortion. Thanks to it's output capability and wide frequency response, this driver is perfect for pairing with high frequency compression drivers. For low weight a high efficiency the 8MB700FT uses an FEA optimized neodymium motor. Extensive venting through the motor assembly and frame keep the large 2-1/2" voice coil cool to handle 350 watts of power with low power compression. AA special composite pulp paper cone and accordion surround delivers natural response with low distortion even when driven to its limits. Suitable with high efficiency home designs, professional sound reinforcement, and even extreme SPL automotive systems, the 8MB700FT-NDY is one impressive midrange driver.
BrandPRV Audio
Model8MB700FT-NDY
Part Number294-2773
UPC602938022569
Weight4.8
Nominal Diameter8"
Bolt Circle Diameter7.75
Power Handling (RMS)350 Watts
Power Handling (MAX)700 Watts
Frequency Response70 to 5,600Hz
Sensitivity98dB 2.83V/1m
Voice Coil Diameter2.5"
Resonant Frequency (Fs)69.97Hz
DC Resistance (Re)5.2Ω
Voice Coil Inductance (Le)0.34mH
Mechanical Q (Qms)2.78
Electromagnetic Q (Qes)0.33
Total Q (Qts)0.3
Compliance Equivalent Volume (Vas)0.66ft³
Mechanical Compliance of Suspension (Cms)0.217mm/N
BL Product (BL)12.78T·m
Diaphragm Mass Inc. Airload (Mms)23.79g
Maximum Linear Excursion (Xmax)3.65mm
Surface Area of Cone (Sd)249cm²
Voice Coil Wire MaterialCCA
Voice Coil FormerFiberglass
Magnet MaterialNeodymium
Overall Outside Diameter8.2"
Baffle Cutout Diameter7.3"
Depth3.66"
Vented Volume0.6ft³
Vented F364Hz
MONSTER DEAL
OF THE WEEK
$19.98 EACH
SAVE $10
